B16A1 Parts?????????????????
Old Mar 24, 2003 | 08:36 PM
91hatchnewb's Avatar
Default B16A1 Parts?????????????????
Ok, I'm about to buy a B16A1 for my 91 hatch and I need to know where I can buy parts for this engine that will fit in my car. Or, do I just buy Del Sol parts or what? Thanks for the replies.
Old Mar 24, 2003 | 08:46 PM
PhatOptimo's Avatar
Default Re: B16A1 Parts????????????????? (91hatchnewb)
Depends on which parts your talking about. Most seals and gaskets internal parts are the same as Del Sol DOHC. Distributor stuff and a few gaskets will be sourced off the 90 integra. It really sepends on the specific part you need. So be more specific and we can help more.
Old Mar 24, 2003 | 08:58 PM
Default Re: B16A1 Parts????????????????? (Phat_Optimo)
well I mean the basic starting out parts like a intake, headers, and exhaust. Also where is the cheapest but best place to buy this engine. So far the cheapest and best looks like inlinefour.com but please let me know if there is a site better.
[Modified by 91hatchnewb, 6:02 AM 3/25/2003]
Old Mar 24, 2003 | 09:05 PM
pokemon's Avatar
Intake should be the same for an 88-91 SI
Exhaust should be for a 91 SI From cat-back
Header should be for a DOHC VTEC Sol
Malgerus's Avatar
Axles (S1 intermediate shaft) Integra '90-'91, any make (non-ABS).
Throttle Cable '90-'91 Integra, any model. Part # 17910-SK7-A03 (Acura)
Clutch Cable '88-'91 CRX Si, may require modification to fit.
Shift Linkage + Torque Rod '90-'93 Integra, requires modification to fit, or buy pre-cut (highly advised)
Clutch Disc Integra non-GSR, '90-'91.
Clutch Plate Integra non-GSR, '90-'91 (?????)
Throwout/release bearing Integra GSR, '92-'93 (?????)
Flywheel bearing Intergra GSR, '92-'93 (?????)
Cam seal endplug Part # 12513-P30-000
Oil Filter Integra GSR, '92-'93.
Valvecover Gasket Part # 12341-PR3-000. del Sol VTEC '94+.
Oil Pan Gasket Part # 11251-P30-004, del Sol VTEC '94+.
Intake Manifold Gasket Part # 17105-P30-004, del Sol VTEC '94+.
Exhaust Manifold Gasket Part # 18115-P30-013, Del Sol VTEC, '94+.
Rear coolant hose (IACV?) Part # 19507-PR3-000 (Honda)
Cam Seals Part # 91213-PR3-013 (Honda)
Cam seal endplug Part # 12513-P30-000 (Honda)
Spark plug tower seals Part # 12342-PG6-000 (Honda)
Valve cover grommets Part # 90442-P30-000 (Honda)
Timing belt cover gasket Part # 11831-PR3-000 (Honda)
Head gasket del Sol VTEC '94+
Fuel injector O-rings Part # 91301-PM7-003, del Sol VTEC '94+
Fuel injector rail cushions Part # 16473-PD6-000, del Sol VTEC '94+
Distributor Cap and Rotor Integra non-VTEC kit from Acura ('90-'91 Integra LS) Part # 06303-PR4-000
Water Pump Part # 19200-P30-003, from a '92-'93 Integra GSR.
Front + Rear Crank Seal Integra GSR, '92-'93.
Throttle body gasket Integra LS, '90-'91 (????). del Sol VTEC does NOT fit.
IACV seal CRX Si (?????)
Upper + Lower Radiator Hose del Sol VTEC, '94+.
Timing Belt Part # 14400-PR3-004, del Sol VTEC '94+.
Spark Plugs Part # BKR6E-11 (NGK copper) GAP: 0.039-0.043
Rear Transmission Bracket Part # 50827-SK7-020, '90-'93 Integra non-VTEC (80% sure)
Coolant hose, back of block to intake manifold Part # 19507-PR3-000, del Sol VTEC '94+.
Old Mar 24, 2003 | 09:35 PM
Default Re: B16A1 Parts????????????????? (Mr. S)
Wow, thanks. I didn't think it was that complicated for me to have to get Del Sol or Integra parts. Thanks again. Any websites you guys know of?
Old Mar 24, 2003 | 09:41 PM
Malgerus's Avatar
http://b16a.honda-perf.org/tech.html
http://www.hondata.com/techwiringpw0.html
http://www.geocities.com/chipman_13/ecu.html (same as B16)
These are my favorites
Old Mar 24, 2003 | 10:02 PM
Thanks a lot. Damn there is a lot that goes into a new engine.
dafiltafish
Aug 6, 2014 04:16 AM
rysingsun86
Oct 11, 2005 04:38 AM
