Need help with JDM D16 swap = sluggish accel, poor gas mileage...
Old Mar 24, 2003 | 07:25 PM
esco72's Avatar
Default Need help with JDM D16 swap = sluggish accel, poor gas mileage...
I just bought a 97 EX and the same day I threw a rod. I got an JDM D16 put in (the cheapest solution). I still have the original computer. Should this make a difference? I know the Us engine produced 127 hp. Is this true of the JDM? Also after this modification I only get 22 mpg, very sluggish acceleration, and my vtec just isn’t trying hard at all. Even for a bone stock civic it’s lethargic behavior doesn’t seem to make sense. I do have an Intake and a muffler, but that’s it! Somebody help me!!
Old Mar 24, 2003 | 08:34 PM
Shift!'s Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (esco72)
JDM D16 = D16Z6 im assuming? Well the first problem I see (if it is a Z6) is that its an OBD-1 engine and your EX has a Y8 which is an OBDII engine I believe.
Old Mar 24, 2003 | 09:34 PM
orange.honda's Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (Shift!)
the only vtec d sieries engines in a 1.6 are the z6 and the y8. so i dont know how much extra you paid to get the same engine that is the same jdm as us specs. but anyhow i agree
so if it doesnt have the p28 like the obd1 92-95 vtec ecu then it wont work properly.
Old Mar 24, 2003 | 11:12 PM
esco72's Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (orange.honda)
I Wish I knew what this all means!!
Old Mar 25, 2003 | 08:10 AM
esco72's Avatar
I still dont know what kind of d16 I have. How would I find out?
Old Mar 25, 2003 | 08:27 AM
MikeMAN's Avatar
there should be a stamp on the front of the block
mike
Old Mar 26, 2003 | 01:51 PM
Shift!'s Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (MikeMAN)
Check the photograph.
the picture shows a B16A engine, and where the stamp in the block is. Its very easy to see and is left of the exhaust manifold. It is like this on all honda engines.
Old Apr 16, 2003 | 06:26 AM
esco72's Avatar
OMG I've been hosed!!
I finally checked the stamp on the engine, and I did not find the D16.. instead it reads D15B!! What the hell is that! I was supposed to have the JDM D16 vtec for a 97 civic. The valve cover does say vtec on it. Can someone please tell me some info on the engine I have in my car?
Old Jun 7, 2003 | 12:23 PM
dragonhaven2001's Avatar
You got owned
Old Jun 7, 2003 | 12:36 PM
ThrillaKilla's Avatar
ha. sorry man.. id go back to the place that gave u that engine.. the engine you were supposed to have is a 1.6 L you got suckered for .1 L of power... i dont know much about 1.5s but is there a vtec 1.5? i think there is .. EX or something..
ok i checked up on it and on my engine list page i found
92-95 Civic, Del Sol, D15B2, SOHC, 16 Valve, 92HP, 24mm Crank snout D15B 1.5 4 $395
it appears that the engine listed there dosn't even have vtec...?
all the other engines equipped with vtec say VTEC...
check out the site if you want.........
http://www.nippon-motors.com/honda.htm
Old Jun 7, 2003 | 02:19 PM
Proper's Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (ThrillaKilla)
Calm down Calm down. There is no JDM D16z6. The D15b Vtec (thereis a non Vtec model) is the Japanese equivelent.and does put out the same amount of power as the z6. It is an OBDI engine though. It's a great motor and mine pulls really hard. But with the wrong ECU I'm sure it runs like ****. So you might want to sell it and get a USDM Y8. Good luck
Old Jun 7, 2003 | 05:50 PM
Touch's Avatar
Default Re: Need help with JDM D16 swap = sluggish accel, poor gas mileage... (CamoHatch)
yeah, you got the infamous d15b its a wonderous little 1.5. enjoy. ****** an ecu off of a 92-95 civic si/ex.
aquito
Jun 13, 2010 10:53 AM
JUN.
13
Dec 29, 2005 05:53 AM
crxautox
Oct 23, 2005 09:43 AM
Fugeeu
25
Aug 16, 2004 08:00 PM
THE *FOB* MOB
Aug 8, 2002 04:36 PM
