fuel problems
Old Mar 24, 2003 | 03:12 PM
rasta420's Avatar
Default fuel problems
working on my friends d16a6...
basically the engine turns over and starts, then after a second of running it cuts off. so we changed the fuel filter, and no progress. we changed the fuel pressure regulator, and now it runs for about 30 seconds then cuts off. whats weird is, when we step on the gas, the car immediately starts bogging and cuts off. i tried starting the car with the throttle open a little bit, and the engine started bucking and it sounded like it was misfiring and detonating.
what could it be? what should i try next?
Old Mar 24, 2003 | 03:23 PM
elpermgrande's Avatar
Default Re: fuel problems (rasta420)
are you throwing any codes?Mine did this when I first dropped my D16A6 in and I changed ecus and that helped also I was trying to start the car with no gas in it.
Old Mar 24, 2003 | 03:31 PM
Malgerus's Avatar
Default Re: fuel problems (elpermgrande)
Sounds like the pump is fragged.
Old Mar 24, 2003 | 07:49 PM
rasta420's Avatar
Default Re: fuel problems (Mr. S)
so its either the fuel pump or ECU? which one could it be for sure, because both are expensive parts...
why would the car run if the pump is messed up? would that rule the fuel pump out? does the car usually run erratic if the ECU is fried?
thanks again
Old Mar 24, 2003 | 09:14 PM
pokemon's Avatar
You sure you changed the ECU and it isn't a DX pm5. That would cause the same effect. Check all vaccuum lines also, if some are confused it will throw codes and the car could run like real ****.
Old Mar 24, 2003 | 09:20 PM
Malgerus's Avatar
Default Re: fuel problems (pokemon)
Why not get a B&M fuel pressure gauge? Then you'll know.
Pena-bb4-620U.M
Oct 28, 2012 07:17 PM
Maple50175
Apr 11, 2009 07:26 AM
czer47
Apr 8, 2007 01:05 PM
boostinh22
Jan 9, 2006 09:52 AM
IAteg
Nov 11, 2005 12:34 PM
