skunk2 coilovers on stock itr shocks
Old Mar 24, 2003 | 01:55 PM
Type S's Avatar
Default skunk2 coilovers on stock itr shocks
im running stock ITR suspension on my 91 integra, i have the opportunity to get a set of skunk 2 coilover sleeves. btw they are for a 90-2000 integra
my question is would they even fit on ITR shocks? and how would the shocks hold up?
ill be running this set up untill i can afford a set of bilsteins
Old Mar 24, 2003 | 02:59 PM
migs's Avatar
Default Re: skunk2 coilovers on stock itr shocks (Type S)
They will fit, they wont hold up for long and will give you an extremely bouncy ride.
Old Mar 24, 2003 | 03:07 PM
Mr Hammond's Avatar
a/k/a Jomo
On the Integra Skunk2 uses 10K front and 8K rear. That is roughly 550lb F and 440lb R. Compare that to GC which uses half that and that's why the ride is alot better. I say get them, but save up and get some revalved Koni Yellow's or off the shelf Bilsteins and swap the rates and run 8K front and 10K rear, but do not drop it more then 2" from stock height. The ride will be firm, but not bouncy. The reason skunk2's are bouncy on stock shocks is they are not valved for such stiff spring rates. The car would be very planted. If you are going for show, just get Ground Controls.
Old Mar 24, 2003 | 03:39 PM
Type S's Avatar
Default Re: skunk2 coilovers on stock itr shocks (Mr Milano)
nah, no show for me, im trying to get a nice set up for roadracing.
if anyone has a set of apex coilovers and is looking to go back to stock, let me know
Old Mar 24, 2003 | 04:27 PM
ITRTurbo's Avatar
don't think the skunk2 will fit on the bilsteins. i tried it once and ended up using them on my koni shocks.
Old Mar 24, 2003 | 04:55 PM
PM-Performance's Avatar
Default Re: skunk2 coilovers on stock itr shocks (ITRTurbo)
they will work fine , i have the same exact set up and it is far from bouncy and it stiffer than GC's
Old Mar 24, 2003 | 05:01 PM
uNF$@#!'s Avatar
apexi coilovers..... i have reservations about that suspension.
i'm not impressed by it at all.
Old Mar 24, 2003 | 07:06 PM
Phoenix_ITR's Avatar
Default Re: skunk2 coilovers on stock itr shocks (Soup ****)
any reason why??
Old Mar 25, 2003 | 12:05 PM
Type S's Avatar
Default Re: skunk2 coilovers on stock itr shocks (delinquent)
yea, why the negativity to the apexi was coilovers?
Old Mar 25, 2003 | 12:10 PM
Reid's Avatar
Global Moderator
What characteristic of your car are you trying to change by changing the suspension?
Old Mar 25, 2003 | 06:19 PM
Type S's Avatar
Default Re: skunk2 coilovers on stock itr shocks (Reid)
well the reason im using the ITR suspension on my 2nd gen is the fact that there is pretty much nothing suspension wise for a 2nd gen.
my car with the ITR suspension is stiffer than on a type R but i want something stiffer and i want the ability to adjust the rideheight.
hopefully my set up will consist of
skunk 2 soilovers
bilstein shocks
Progress swaybars
all tie bars
autopower roll bar
joshb_
Suspension & Brakes
Mar 24, 2008 08:51 AM
99fbpem1
Sep 29, 2007 01:02 PM
japmarket1
Oct 4, 2005 05:36 PM
Clutch784
Oct 17, 2002 07:17 AM
tweekerz
May 21, 2002 08:31 AM
