Welding Aluminium to Stainless Steel?
Old Mar 24, 2003 | 12:03 PM
pub's Avatar
pub
Default Welding Aluminium to Stainless Steel?
..as the topic says: can it be done?
I have MaxRev stainless steel piping and a fabricated aluminium BOV flange (thank you local Machine Shop). I was wondering if this could be welded together? I guess there would need to be a little pipe extention.
thanks for the comments beforehand.
Old Mar 24, 2003 | 12:05 PM
psi420's Avatar
Default Re: Welding Aluminium to Stainless Steel? (pub)
Not a pro, but as far as I know, NO.
Old Mar 24, 2003 | 12:10 PM
b18bturbo's Avatar
Default Re: Welding Aluminium to Stainless Steel? (psi420)
it cna be done but requires alot of equipment and deep under water welding to come out clean
Old Mar 24, 2003 | 12:15 PM
pub's Avatar
pub
Default Re: Welding Aluminium to Stainless Steel? (b18bturbo)
Not so much concerned with cleanness. Just want to make sure my BOV holds.
Old Mar 24, 2003 | 12:16 PM
b18bturbo's Avatar
only thing you can try is jb weld. .it will hold for some time .. but you really cant weld stainless to aluminum
Old Mar 24, 2003 | 12:30 PM
t04s's Avatar
That's exactly right, a couple years ago Frank a dss was going to experement with some axles with a config like that.
Old Mar 24, 2003 | 12:50 PM
Smashback's Avatar
might be possible not really feasable...options:
1. weld the flange onto a piece of al. pipe and use hose and clamps to intall it inline on your charge pipe
2. weld a stub of pipe the same size as the flange onto your charge pipe, and secure the flange to the stub with hose and clamps. probably your best bet...same way you install a bosch or similar bov (except they don't have a seperate flange, but it works out the same.
Old Mar 24, 2003 | 12:59 PM
pub's Avatar
pub
Default Re: Welding Aluminium to Stainless Steel? (Hatchblack)
don't exactly get what you're saying here. The way my BOV (MaxRev) you need a flange. I guess I could just take my aluminium flange to the machine shop and get them to make a Stainless steel flange. That's another $10 though.
Old Mar 24, 2003 | 01:33 PM
Smashback's Avatar
Yeah, so say the flange is 1" where it attaches to the charge pipe.
1. Weld 2" long piece of stainless 1" dia pipe to charge pipe
2. clamp 1" i.d. rubber or silicone hose to pipe you welded onto charge pipe, secure with hose clamp
3. insert bov flange into other end of hose, secure with hose clamp
4. install bov onto bov flange...wala
Somebody with a clamp on bov like dsm or bosch help me out with a pic here!
[Modified by Hatchblack, 10:33 PM 3/24/2003]
Old Mar 24, 2003 | 03:05 PM
mos's Avatar
mos
Default Re: Welding Aluminium to Stainless Steel? (jz)
You might be able to find some brazing rod that is compatible with both aluminum and stainless steel. Not sure though. That's what I'd look into first. As stated above, it might be easiest to just get a short al pipe and use some clamps.
Old Mar 24, 2003 | 03:11 PM
pub's Avatar
pub
Default Re: Welding Aluminium to Stainless Steel? (mos)
ah. I see what you mean now. Good way of looking at it.
My other option was to buy one of them cheap ebay CAI's for $25 and have a nice mandrel bent aluminum charge pipe that fits right on my throttle body. Also saving me money for the welds I'd be making for the stainless steel cuts.
Old Mar 24, 2003 | 04:01 PM
Smashback's Avatar
that's what i got...i love aluminum...lightweight and bling shiny bling
1baddturbosi
Welding / Fabrication
Dec 12, 2006 04:41 PM
EK k kay
Jan 28, 2006 09:58 PM
rice a roni
17
Apr 8, 2005 07:58 AM
Wo-Nelly
Dec 28, 2002 06:50 PM
Snafu-Si
Apr 29, 2002 05:10 PM
