What valvespring compressor do you use?
Old Mar 24, 2003 | 11:52 AM
B19CivicHB's Avatar
Default What valvespring compressor do you use?
I bought a shitty craftsman OHV spring compressor and it just wont cut if for my GSR's valvesprings.
A local shop wants $350 for a 3 angle valve job, disassembly and reassembly of the head.
For just the valve work (assuming i bring them a bare head) it is $125.
Id like to save that $225 if at all possible.
Anyone have a suggestion on a good vavle spring compressor to get? Or do you think the $350 is a reasonable price (keep in mind I already have the new seals, springs reatainers and intake valves).
Thanks!
-Nick-
Old Mar 24, 2003 | 12:23 PM
dfoxengr's Avatar
Default Re: What valvespring compressor do you use? (B19CivicHB)
i got one from the local parts store..just a cheap OHV spring compressor...hte kind that has the things on the side, and a screw/bolt thing in the top that you tighten, ol vague............
Old Mar 24, 2003 | 02:51 PM
rustyeleio's Avatar
I have a 92 Accord and the standard screw type compressor with the two little hook arms didn't fit my springs with out a whole lot of struggling (too big). It also couldn't compress far enough so I had to use a short body O2 sensor socket over the retainer to get enough compression. Personally if I had to do it again I would get one of those bolt down lever arm-spring compressors (bolts into the cam holder holes). Someone here has a homemade one but I forgot where I saw that thread, otherwise they are hard to find.
gucci mane
Dec 12, 2013 07:48 PM
HumanResource
Jan 8, 2009 07:31 AM
averyvm
23
Feb 27, 2007 06:54 PM
93b16
Feb 2, 2005 04:47 AM
infinkc
Dec 24, 2001 12:46 AM
