assebly lube
Old Mar 24, 2003 | 10:32 AM
eddiecut's Avatar
Default assebly lube
whats everybody using?
Old Mar 24, 2003 | 11:23 AM
altoid's Avatar
Default Re: assebly lube (eddiecut)
vasoline, engine oil, wd40
Old Mar 24, 2003 | 11:33 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: assebly lube (altoid)
sealed power assembly lube. thats what it is for.
i use it everywhere. and i pack oil pumps with vasaline.
although tranny fluid and motor oil is ok but if you dont have the engine done quickly, it is good to use something that will stick to things and not run off.
Old Mar 24, 2003 | 12:10 PM
igyloo's Avatar
redline
Old Mar 24, 2003 | 02:53 PM
rustyeleio's Avatar
The black stuff in the aqua tube from Pep Boys. Easy to find.
Old Mar 24, 2003 | 05:02 PM
Tweakmeister's Avatar
i like a high moly lube
Old Mar 24, 2003 | 08:45 PM
eddiecut's Avatar
Default Re: assebly lube (Tweakmeister)
redline wins, went and got some today
Old Mar 24, 2003 | 09:07 PM
irev210's Avatar
I use the same thing, tho im sure someone on honda-tech will tell me its bad for hondas for some reason
Old Mar 25, 2003 | 08:32 AM
Default Re: assebly lube (irev210)
no one should ever complain about a moly lube.
that's like saying gas is bad for the fuel injectors...
Old Mar 25, 2003 | 09:21 AM
IN VTEC's Avatar
ARP moly lube is my lube of choice.
I also use 30W oil for coating everything that doesn't use the moly lube.
Old Mar 25, 2003 | 12:39 PM
GZERO's Avatar
Default Re: assebly lube (IN VTEC)
like what?
Old Mar 25, 2003 | 01:03 PM
94CivicSi's Avatar
Default Re: assebly lube (boostedcivicsir)
How packed is "packed". Just the rotors or do you force the vaseline down the screen pick-up and up the through the block port?
Old Mar 25, 2003 | 01:54 PM
IN VTEC's Avatar
Default Re: assebly lube (GZERO)
Pistons, piston rings, valves, valve springs....everything.
Old Mar 25, 2003 | 02:19 PM
Katman's Avatar
asstro glide.
Old Mar 25, 2003 | 07:53 PM
Mr. Badwrench
just the rotors.
its a trick i took from building buicks. if you drystart a buick it takes way longer for the oil to reach the pump from the pickup. basically it helps draw up oil a little faster. been doin it on small blocks too.
zoso
Jun 24, 2008 02:21 PM
Jedimiah
Nov 7, 2006 08:52 PM
Mike banX
10
May 17, 2004 12:18 PM
JDubya
Dec 6, 2003 09:37 AM
calcnerd
Sep 30, 2002 11:25 AM
