Is this supposed to happen?
Old Mar 24, 2003 | 07:59 AM
oryanh's Avatar
Default Is this supposed to happen?
I hooked up my wideband O2 last night. (the tech edge kit)
I noticed I'm pretty spot on (14.6-14.8) most of the time... Except when I let off the gas, it spikes to 20:1+...
Is that normal?
Also, at WOT I'm around 12.2:1 - 13:1 Can I lean this out a bit?
What's a safe WOT A/F ratio?
Old Mar 24, 2003 | 10:52 AM
oryanh's Avatar
Default Re: Is this supposed to happen? (oryanh)
bump>
There's got to be some A/F guru's in here.
Old Mar 24, 2003 | 12:53 PM
sgT's Avatar
sgT
in closed loop situations the ecu will use the stock o2 sensor to hunt for stoich.
as for if you can lean out the mixture, dont you have an afc or something?
Old Mar 24, 2003 | 01:04 PM
Asahi's Avatar
Default Re: Is this supposed to happen? (sgT)
I found 13.7 was the best A/F for my car. (Made the most power across the rpms)
I am sure this will vary some. Under WOT conditions you will want it around 13.5 across the board.
You can lean it out more at lesser vacuum settings. I think it was suggested at 1/2 throttle you can aim for about 14.7. . . Steve?
Trey
BoldFart16
Engine Management and Tuning
12
Mar 12, 2011 06:09 AM
turbotime
Oct 10, 2005 08:51 AM
evilcivilian
Oct 5, 2004 10:52 AM
turbo Si
Mar 10, 2003 02:56 PM
liam821
Feb 8, 2002 11:31 AM
