o2 sensor voltage at WOT
Old Feb 7, 2002 | 11:21 PM
liam821's Avatar
25 Year Member
Default o2 sensor voltage at WOT
Does anybody know what the o2 voltage should be at WOT in my mighty sohc vtec?
I installed 450cc injectors and tuned my afc -35% and i think my a/f (pos autometer) is giving me wierd answers. Right now its around .90 volts at WOT which i think is rich but my a/f gauge shows dead lean. The car seems to run pretty good although im being really easy as i dont want to blow it up. Idle is nice and smooth.
If i tune my AFC to -20% the stupid a/f still shows super lean but the car barly idles and runs pretty ruff. The o2 voltage shows .95 -> .96 which im pretty sure is super super rich.
Any ideas on my fuel problem?
thanks,
liam
Old Feb 8, 2002 | 05:55 AM
VTC_CiViC's Avatar
Default Re: o2 sensor voltage at WOT (liam821)
O2 voltage is gonna vary depending on what the sensor is reading in the car (rich/lean). Shouldn't be affected by your AFC, at least not directly. Your MAP is what's manipulated by the AFC
Old Feb 8, 2002 | 11:22 AM
liam821's Avatar
25 Year Member
Default Re: o2 sensor voltage at WOT (VTC_CiViC)
although o2 voltage does very by what the AFC does. The richer the car runs, the higher the o2 voltage.
Checkout this chart..
You notice as the o2 voltage increases, as does the flashy lights. Im reading .90 volts but the gauge is reading dead lean. So either my volt meter is reading wrong (unlikely) or the guage is broke...which is much more likely.
Im guessing i want to tune my car to around .92 volts which is somewhat rich but should be good for turbo.
liam
Old Feb 8, 2002 | 11:24 AM
boosted hybrid's Avatar
You should shoot for between .88-.91 which is approxiametly 11:1~12.5:1. I am running about .90 right now...12psi, stock block no pinging.
Old Feb 8, 2002 | 11:31 AM
liam821's Avatar
25 Year Member
Default Re: o2 sensor voltage at WOT (boosted hybrid)
Cool thanks for the input.
liam
ATS*Mark
Apr 7, 2004 07:06 AM
Joel_MN
Apr 1, 2004 11:15 PM
Maxime
Feb 24, 2004 11:05 AM
turbo Si
Mar 10, 2003 02:56 PM
