welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve
Old Mar 23, 2003 | 09:29 PM
roydogg's Avatar
Default welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve
Even though I cut the cai for the bypass valve can I still weld a BOV flange to it and use it as my IC pipe.
Old Mar 23, 2003 | 09:47 PM
UberTeg's Avatar
Default Re: welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve (roydogg)
sell it for $100, and use that money to buy regular piping
Old Mar 23, 2003 | 09:58 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
... Im' not sure I understand.. You mean like this?
Like how I have my BOV on my AEM intake? Look under my intake.. I mounted it it upside down or it would have hit my strut bar.
Just trying ot make sure i know what you mean.
Old Mar 24, 2003 | 12:02 AM
X2BOARD's Avatar
Default Re: welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve (Snafu-Si)
Schweet..... I was thinking about doing that too... How did you get it welded on ? Since the AEM is aluminum... did you need to get it tig welded ?
X2
Old Mar 24, 2003 | 06:13 AM
IntegD's Avatar
New User
Default Re: welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve (X2BOARD)
I'll be the first to reply that I had to go to a specialty welding shop to get my aluminum Greddy flange welded on my AEM. Make sure if your gonna do it on your AEM pipe that you get an aluminum BOV flange or else their going to tell you that you cant weld aluminum to steel.
OH..btw, I would get rid of the bypass valve once you go turbo. You can find some way to rig it to make it fit if you want to save some cash. If not, you can always buy drag piping for like 400 bux or something of that sort. Either way, piping is gonna blow off at 15psi...
[Modified by IntegD, 7:15 AM 3/24/2003]
Old Mar 24, 2003 | 08:16 AM
MikeMAN's Avatar
i used my CAI for my bov, and it had a bypass on it.
i used a pipe coupling to seal off where the bypass was, and then had my BOV welded on...
Old Mar 24, 2003 | 09:42 AM
roydogg's Avatar
Default Re: welding bov to AEM cai? Using it as my intake charge pipe, been cut for bypass valve (MikeMAN)
I think I'm gonna use my aem cai and just use some couplings where it was cut for the bypass valve. And buy a aluminum flange for the greddy type S.
Old Mar 24, 2003 | 10:10 AM
Snafu-Si's Avatar
My friend is a mechanic at Ford and knew this guy name Chuck Watson of Waston Engineering in Taylor Michigan. Very big place, no public work. They only do work for componies liek Ford and special division like the SVT people. But.. I got the hookup and he did it for me for free.
X2
nekoabandoned
Nov 26, 2005 02:49 PM
AirWaveGT
Mar 28, 2004 08:41 PM
navz121
Dec 20, 2003 12:42 AM
bluebullet
Jul 3, 2002 08:15 AM
