Running Rich
Old Mar 23, 2003 | 08:44 PM
wantmorepower's Avatar
New User
Default Running Rich
I have the (chipped) p28 ECU for my b18c5. It seems that whenever I drive it –it always runs rich according to my air/fuel meter. Sometimes it would go in the middle of the gauge but most of the time it is in the green (when I am not at WOT). When I park my car at night I can smell the fuel. Should I be concerned? I know that lean condition is bad for the car however does excessive rich condition wipe the cylinder walls of needed oil. Does anyone know? Thanks
Old Mar 23, 2003 | 08:53 PM
hoya_10fintec's Avatar
Default Re: Running Rich (wantmorepower)
tune it...
Old Mar 23, 2003 | 10:32 PM
orange.honda's Avatar
Default Re: Running Rich (hoya_10fintec)
the reason you are running rich is because your ecu is chipped. because it is not a custom fuel map for your specific mods and engine it will not run its best. if you had a programmable system like hondata then you could tune it and run much better. running rich will leave unburned or partially burned fuel in your cylinders adn will cause carbon build up.
turbo-d
Feb 4, 2005 04:58 PM
H22CL
Jun 20, 2004 11:11 AM
mario82686
14
May 7, 2004 09:11 PM
jeremy.
Sep 27, 2003 02:12 PM
Dokta
Feb 23, 2002 07:37 PM
