electric lock problems??? HELP
Old Mar 23, 2003 | 04:00 PM
spencedogg's Avatar
Default electric lock problems??? HELP
Hey guys my locks on my 96 keep locking and locking and locking it must lock 40 times in 5 minutes i have no idea what is wrong please help
Old Mar 23, 2003 | 04:43 PM
Chiovnidca's Avatar
Default Re: electric lock problems??? HELP (spencedogg)
That's usually caused by a bad drivers door lock actuator.
Old Mar 23, 2003 | 04:54 PM
spencedogg's Avatar
Default Re: electric lock problems??? HELP (TurboD16Chiovnidca)
how much it cost where can i get it and where is it located in the car?
thanks
Old Mar 23, 2003 | 06:21 PM
mwkirchner's Avatar
It is hard to say what it will cost you ... but my guess would be around $60.00 or so (for the part ... NOT including labor). It is attached to the driver's door latch. You have to remove the door panel and put the window in its utmost up position to access it. The easiest way to replace it is to remove the lower metal window channel run and remove the 3 screws holding the latch to the door. You can then bend it around enough to remove the screws that hold it to the latch. Not too easy to try to tell you how to do it exactly ... but that will give you a general idea.
Most garages will charge you an hours labor to replace this part.
[Modified by mwkirchner, 12:07 AM 3/24/2003]
Old Mar 23, 2003 | 07:32 PM
spencedogg's Avatar
so is this something i cant replace myself then????
Old Mar 24, 2003 | 07:30 AM
Superorb's Avatar
i tried this myself, what a bitch, i broke the damm door handle getting the lil rod out of it, the haynes book ist right for **** in this part of the car....
i got my actuator for 10 bux form a yard, and my dad fixed it, mr mechanic
take it to a shop, they will charge u an hours labor, make sure to tell them that you want back the part they replaced.
tallypbplayer
Mar 17, 2010 09:53 PM
casper.hughes
Oct 12, 2008 06:33 PM
206civic
Jan 8, 2005 11:43 AM
eddie1681
Feb 24, 2003 10:33 PM
*Boostwerks*
Sep 13, 2002 08:52 AM
