... diy ghetto boost control mod for 2psi... what do you think???
Old Mar 23, 2003 | 08:33 AM
1.8T_EG's Avatar
Default ... diy ghetto boost control mod for 2psi... what do you think???
quick boost controller...on the boost source from the turbo put a vaccum "T" in the vaccum line
and leave one end open ..this is good for 2psi
... i found this on another board... what do you think?... i guess it works just like a bleed-type boost controller... any thoughts/opinions?... thanks...
Old Mar 23, 2003 | 08:58 AM
93LSivic's Avatar
Default Re: ... diy ghetto boost control mod for 2psi... what do you think??? (1.8T_EG)
Its also good for a vacuum leak when not in boost.
*edit.
You can build a mbc for about $4. 3 way female threaded bass "T", spring, ball bearing, bolt and nut, and 2 barbed hose fittings. Thats it.
[Modified by 93LSivic, 1:01 PM 3/23/2003]
Old Mar 23, 2003 | 09:28 AM
1.8T_EG's Avatar
Default Re: ... diy ghetto boost control mod for 2psi... what do you think??? (93LSivic)
*edit.
... will there still be a vacuum leak if it used with a deltagate where the boost source goes from the turbo to the wastegate?... thanks...
thegatekeeper14
Jul 6, 2010 12:53 PM
SOHC_MShue
Jan 15, 2005 05:03 PM
EKB18BPR3
Jul 3, 2004 09:19 PM
boostdB16a
Jul 8, 2003 06:10 PM
accordfreak
Dec 25, 2001 12:20 AM
