tried to get an alignment yesterday, but they couldn't do it...
Old Mar 23, 2003 | 06:50 AM
xcathodex's Avatar
Default tried to get an alignment yesterday, but they couldn't do it...
because my car was hit in the rear. i can't afford to have someone try to straighten it, and i doubt it's worth it anyway; can i do anything to fix this myself?
the problem is about 1.5 degrees of toe-out on the right rear. i've inspected the control arms and strut assembly and nothing seems visibly damaged or bent, although quite obviously SOMETHING is. is there any way i can bang the drum back to where it needs to be with a rubber mallet or something? or am i beyond hope?
Old Mar 23, 2003 | 07:05 AM
Trinity's Avatar
Default Re: tried to get an alignment yesterday, but they couldn't do it... (xcathodex)
i would say replace that side of the suspension. see if that helps. what exactly is bent on it
Old Mar 23, 2003 | 07:18 AM
xcathodex's Avatar
Default Re: tried to get an alignment yesterday, but they couldn't do it... (Trinity)
that's the thing, neither of the arms seem bent, nothing appears bent. it's probably the damn frame
Old Mar 23, 2003 | 08:56 AM
Rywire's Avatar
I had a bent wheel, when I hit a curb. It pushed my front passenger side wheel foward, and in. I went to the junk yard, and got a new knickle, control arm, and strut support rod. I put it in, and it was close to straight. None of the parts looked bent, even when I put them next to eachother. To make the wheel straight, I had to bend that piece on the body that supports the inner lower control arm. I had this done profesionally. It costs about 400 to fix it all, included... Junk yard parts, new rim, swap tires, and shop time to bend back lower arm support. Your problem could be any or all of these problems. Ryan
Old Mar 23, 2003 | 03:02 PM
SiR Kid's Avatar
New User
Default Re: tried to get an alignment yesterday, but they couldn't do it... (droppedcrxsi)
Get a full rear disk swap from a 90-91 CRX Si. Install it all with the control arms that come with it. Take it back to have an alignment done. Voila, fixed alignment and disk upgrade for less than$300.
Old Mar 23, 2003 | 04:06 PM
Ef Whore's Avatar
Default Re: tried to get an alignment yesterday, but they couldn't do it... (SiR Kid)
tell you the truth if u didnt hit a curb, and were hit in the rear, most likely the frame is bent. Dont bother trying to replace ****, I'd just deal with it and save up for a new EF.
Old Mar 23, 2003 | 04:19 PM
xcathodex's Avatar
Default Re: tried to get an alignment yesterday, but they couldn't do it... (Ef *****)
that's my plan ...this one is a beater anyway
Old Mar 23, 2003 | 04:26 PM
Buzz Kill's Avatar
One of the easy places to bend up the rear is where the lower member attaches to the body, If you have seen a lower rear bar, this is where the bar bolts up. See if there are any dents on the channel between the two points. If there are dents, you could try to pull it out with a rented portapower.
fryman
14
Jan 30, 2013 08:13 PM
RiTtEk401
17
Oct 7, 2011 10:38 AM
vtec25
Dec 30, 2007 04:20 PM
TealEG!
Suspension & Brakes
Oct 20, 2005 08:24 PM
smitherton
Jan 3, 2005 10:13 AM
