Poor Idle - Need Help
Old Mar 23, 2003 | 12:13 AM
4doortypeR's Avatar
Default Poor Idle - Need Help
The car drives good, but once you come to a stop it idles like it wants to shut off;
worse with a/c on. I have changed the IAC sensor and most sensosrs on the Intake manifond , cleaned the Manifold as well as trottlebody.
I have changed the PCV valve as well.
I am out of ideas now.
Any suggestions?
1996 JDM ITR b18cR.
Engine was recently rebuilt but had the same problem before it
was overauled.
All suggestions welcomed.
Old Mar 23, 2003 | 01:18 AM
intekragsr's Avatar
Default Re: Poor Idle - Need Help (4doortypeR)
could also be coolant related since idle is related to coolant temp. Check for bubbles, contamination, ect ect.
Old Mar 23, 2003 | 05:02 AM
Chiovnidca's Avatar
Have you done compression or leakdown tests?
Old Mar 23, 2003 | 07:27 AM
DK4200's Avatar
Default Re: Poor Idle - Need Help (TurboD16Chiovnidca)
bleed the coolant... if no bleader then change it right out... i did that and also put on Hondata Intake manifold gasket and my car idles alot better now
phrenzykEG6
16
Jun 17, 2010 08:42 PM
Silent_Destruct
May 24, 2006 02:10 PM
Sinner
May 29, 2003 10:41 AM
g2style
Feb 4, 2003 10:09 PM
Turbo Powa
Oct 7, 2002 11:58 AM
