A Turbo mounted sideways..help!
Old Mar 22, 2003 | 09:54 PM
H22CRX's Avatar
Default A Turbo mounted sideways..help!
Is it possible to mount a turbo sideways? Meaning the usual air filter end would be upwards toward the hood. I really don't see a reason why you couldn't but I'm not totally sure. Me have no space!
Old Mar 22, 2003 | 09:56 PM
GSRrR's Avatar
Default Re: A Turbo mounted sideways..help! (H22CRX)
Anything is possible with lots of $
Old Mar 22, 2003 | 10:47 PM
turbopimp's Avatar
If I understand you correctly, the answer is NO... reason being that the oil will not drain back to the pan properly, since it relies on gravity alone to drain. The exception to this would be if you are using a turbo with self contained lubrication such as an Aerodyne.
Old Mar 22, 2003 | 11:17 PM
LiLOtaku's Avatar
Default Re: A Turbo mounted sideways..help! (turbopimp)
I thought oil pressure would help to push out the oil out of the turbo center section and into the oil pan since it gets pressure from the back of the block via the oil pressure line.
Old Mar 22, 2003 | 11:19 PM
pissedoffsol's Avatar
25 Year Member
Default Re: A Turbo mounted sideways..help! (LiLOtaku)
there is next to no pressure in the return. it relies on gravity
Old Mar 23, 2003 | 02:34 AM
Stu's Avatar
Stu
New User
Default Re: A Turbo mounted sideways..help! (delvtecsol)
The answer is no. Better get more creative so you can fit one in there. Why don't you post a picture of your engine bay so the turbo gurus and geniuses can look at it and give you some ideas.
Old Mar 23, 2003 | 08:56 AM
93LSivic's Avatar
Default Re: A Turbo mounted sideways..help! (Stu)
Actually, you guys are wrong. All you need to do is install a pretty expensive oil sump setup
Old Mar 23, 2003 | 10:12 AM
H22CRX's Avatar
Default Re: A Turbo mounted sideways..help! (93LSivic)
I thought about that idea being that my motor doesn't lean back like normal H22's so I put extra oil in motor to compensate. What do those oil sump systems run? Where can I get one if the price isn't too high?
Bigrederic
Apr 29, 2010 06:18 AM
99Sivic
May 7, 2006 01:39 PM
CRXDrew
Apr 14, 2005 03:55 PM
94TurboGSR
Sep 3, 2003 05:30 PM
SpyLude92
Feb 15, 2003 02:04 PM
