No knock sensor = less power?
Old Mar 22, 2003 | 08:34 PM
granada_sun's Avatar
Default No knock sensor = less power?
Alright my b16 doesnt have a knock sensor installed, and I get the CEL. Somewhere I heard that the ecu will go into safe mode when the CEL is on, is this true?
edit-and if it is, how does it affect the output of the engine? Appreciate the help.
[Modified by Dark_Sol, 12:36 AM 3/23/2003]
Old Mar 22, 2003 | 08:59 PM
Default Re: No knock sensor = less power? (Dark_Sol)
n/m, limp mode sucks.....
Old Mar 22, 2003 | 09:51 PM
Chiclets's Avatar
if ur cel is on and its cuz of ur knock sensor then it means that ur vtec is not engaging and ur car is not putting out the top end power it should
the easiest way to fix it is to go and buy a knock sensor but if you don't want to buy one then do a seach on how to by pass it
Old Mar 22, 2003 | 09:57 PM
Kamin's Avatar
just for clarification
not any CEL will put the ecu into limp mode
only major ones
like the knock sensor.
Old Mar 22, 2003 | 10:19 PM
NonovUrbizniz's Avatar
Loved
Default Re: No knock sensor = less power? (Kamin)
If your in limp home mode... you'll know it.
If your car revs to redline or engages vtec... you aren't in limp home mode....
Old Mar 23, 2003 | 08:12 AM
b18bvtec4drteg's Avatar
VTEC still kicks in without the knock sensor.
Old Mar 23, 2003 | 08:22 AM
eg6ajk's Avatar
yes it does effect the power.
what ecu does when it goes into a major 'limp' mode/code it retards the timing/richens up the fuel maps
I suggest fixing the problem or disabling the knock by either reprogramming or using a 1k resistor connected to the ground.
Old Mar 23, 2003 | 08:43 AM
Default Re: No knock sensor = less power? (eg6ajk)
See, VTEC engages, but the CEL still comes on.
Now what about the 1k resistor to the ground???
Old Mar 23, 2003 | 10:34 AM
Kamin's Avatar
Default Re: No knock sensor = less power? (b18bvtec4drteg)
in limp mode vtec will not work.
Old Mar 23, 2003 | 11:47 AM
Its not in limp mode then. But the CEL still comes on.
Old Mar 27, 2003 | 08:21 PM
FitCRX's Avatar
1k to the ground? I need to know how to do this.
What am I grounding the connection to the back of the block through a 1k to ground?
Or ECU?
obd0
Old Mar 27, 2003 | 08:23 PM
Kamin's Avatar
nooo if the knock sensor code is throwing
your in limp mode.
whats your rev limit?
Old Mar 27, 2003 | 08:28 PM
FitCRX's Avatar
<CODE 23, REV to 8200 all day
vtec ingages
Engine seems slack
Old Mar 27, 2003 | 08:32 PM
BluntMan's Avatar
if vtec still kicks in, then your not in safe mode. and im pretty sure that the knock sensor not being there wont put you in safe mode. and you would sure as hell notice when the ecu is in safe mode! and not all cel's would throw you in safe mode, only the major one's, like tps, map, etc. just throw a nock sensor on the bitch, or bypass it. its easy as hell!
Old Mar 27, 2003 | 08:34 PM
FitCRX's Avatar
Default Re: No knock sensor = less power? (BluntMan)
Bluntman....tell us how to by pass it.
Old Mar 27, 2003 | 08:47 PM
BluntMan's Avatar
Default Re: No knock sensor = less power? (FitCRX)
throwing a knock sensor on is easy, but to bypass it you'll have to find out what voltage the knock sensor throws out to the ecu. ive never done it but im sure it cant be too hard. ill try to find out for you.
Old Mar 27, 2003 | 09:16 PM
turbod92hatch's Avatar
my friends b18 doesn't have a knock sensor, check engine is on and still runs like a bat out of hell but when the light isn't on it won't run for nothin. get a p28 ecu, it doesn't have a knock sensor in it. that will solve your problems. you can't program it out and the hole grounding thing i have never heard of so you decide.....
Old Mar 28, 2003 | 04:25 AM
b20guy's Avatar
Default Re: No knock sensor = less power? (turbod92hatch)
ive got a practically brand new knock sensor, $50.. sorry to butt in guys, but my b20 doesn't need it so why not sell it?? It's got 1500 miles on it.
Old Mar 28, 2003 | 05:00 AM
eg6ajk's Avatar
Or ECU?
obd0
cut the connection between the ECU and knock use the side that comes out of the ECU add the 1k resistor and simply ground it. this should take care of your problem.
Old Mar 29, 2003 | 12:48 PM
Does anybody have a site that shows how to install a knock sensor, as in wire it to the ecu? I checked c-speed, and yahoo n ****, but no luck......
Old Mar 31, 2003 | 07:56 AM
degooser's Avatar
Or ECU?
obd0
is this for an obd I motor or what?
this seems like a cool way to do this..
and does this really work?
[Modified by degooser, 7:06 PM 3/31/2003]
Old Mar 31, 2003 | 12:37 PM
Katman's Avatar
...just get the ecu reprogrammed with a disabled KS. It's as simple as that.
Old Mar 31, 2003 | 01:37 PM
94TealGSR's Avatar
My P72 absolutely does not go into limp mode without a knock sensor. It will throw code 23 all day (once i rev past 3000... otherwise no code 23), but even with the CEL on it will rev to 8000.
Old Apr 1, 2003 | 07:47 PM
degooser's Avatar
I tried this and it didnt work... still got the cel...and specifics that might cause it not to work???
or does this really not work.....
Old Apr 1, 2003 | 08:28 PM
Default Re: No knock sensor = less power? (94TealGSR)
Same here, with p30 CEL goes on, but vtec still engages and pulls like a bast.
