which route to take, NA or BOOST
alright heres what i got..ive got a 91 crx with the b16a in it..i havent decided what i should do weather it be cams, cam gears, valves, porting etc etc, or take the turbo route..now would there be a lot of customizing for me to go turbo and would i have to put some $ in the bottom end so it wouldnt blow..what am i looking at here and what are your opions..i also know tractioin is a serious factor seeing how i have no LSD?? any opions would be greatly appreciated..thnks
i'd say turbo, in the end allmotor wont' get you the speed you're gonna want. atleast that's how i feel. I remember 2 years ago my goal was 13's, and now that's nothing to be proud of at all. i'm going for 11's at least, then when i get there i'm sure i'll want 10's.
I am fighting the same decision right now.... I have sorta found that it would cost more $$/hp to go N/A than turbo. Like you could get more power from a turbo setup for cheaper, than going all motor. Another big issue for me is my car is a daily driver, and i need it to be dependable.
However, i am still curious how much custom fabrication must be done to cram this setup into a crx.... I have heard that you really dont have to do any build up of the motor, as long as you keep it at low psi, 5-7psi...
well i was reading the new HONDA Tuning magazine. they had a crx with a turbo on it from parts of a eclipse and hf manifold. It dynoed at 172 and 161, pretty good i think. stock internals at 5 psi. Says not to go over 7
This is what I'm doing right now.> http://www.homemadeturbo.com
4thGSi that setup looks crazy
i like it..i want to be able to have arround 200 or so horse at the wheels and around 180 ft lbs of tourqe..think that would be do able considering i want to leave the bottom end stock?..i heard you can do a piece by peice turbo setup for around 3200..would i have to do anything to my front cross member to fit a turbo in?..what about radiator..well anyway thanks for any advice..also if any of pics of your setups in a crx that would be cool..
[Modified by 4thGSi, 8:10 AM 3/23/2003]
Id say boost it......
I have been thinking about the same for quite a while, I was a N/A man. I wanted my b16 to be a n/a monster: cams, headwork, tb's and stuff. That setup I had in mind was gonna cost loads........for,hmmmm 220hp? And still no torque? So I turboed my b16. Love it............
I ment bout 220 hp for a possible n/a setup.........................If you boost a b16, the hp possibilities are way higher.
I have no clue on figures now, havent dynoed it yet but I guess it will be between 210 and 230 right now. Torque no idea.
I have a greddy kit but lost blue box and put inline pump and fmu on it. Still needs work on tuning.......
