eNeed Help With Head Swap
the motor in my car is an f22b2, i have a totaled 94ex with a f22b1, the haynes manual for the cars says that, teh engines are the same, the only difference is one has a v-tec valve train. Does anyone know if i can just switch the heads and computer and run an extra oil line, and wires? I DO NOT want to do a h22 swap because i need my car to goto work and I want it to seem stock, also would the non v-tec valve cover fit? You know the whole under cover rice rocket thing.
Heh, I have an F22A6 ('92 EX SOHC non-VTEC) and F22B1 ('94 EX SOHC VTEC) being torn down in carport as I type. The comparison should be similar to your motors. I doubt all the oil and coolant ports between the block and heads will line up, but I'll let you know.
scotemoney
Jun 27, 2005 04:31 PM
TheBobFather
Jun 25, 2005 09:29 AM
