Turbo timer install help....calling all 92-95 civics.....
Old Mar 21, 2003 | 08:47 PM
wickedxboi's Avatar
Default Turbo timer install help....calling all 92-95 civics.....
what color or colors(i think it should be 2 wires) are the ignition wires under the steering wheel do i tap? i have a older style apexi turbo timer. any help will be nice...thanks in advice
Old Mar 21, 2003 | 09:02 PM
norcalcrx's Avatar
Default Re: Turbo timer install help....calling all 92-95 civics..... (wickedxboi)
Here you go this link helped me alot when i installed mine.
http://importnut.net/turbotimer.htm
And a multimeter.
Old Mar 22, 2003 | 08:41 AM
wickedxboi's Avatar
Default Re: Turbo timer install help....calling all 92-95 civics..... (norcalcrx)
that link didnt help to much.......anyone else?
Old Mar 22, 2003 | 07:06 PM
luckypon7's Avatar
try http://www.pfispeed.com click tech help then it is under tips...
Old Mar 22, 2003 | 11:03 PM
highmilehatch2's Avatar
Default Re: Turbo timer install help....calling all 92-95 civics..... (luckypon7)
Ok, here goes: from the timer harness green, that goes to the yellow wire, red goes to the big fat white wire, (there are two white wires you need the fatter one), the blue wire goes to the black wire with the yellow stripe, black to ground! You have to cut the black plastic wrap that surrounds these wires to get to them.
Old Mar 24, 2003 | 08:45 AM
wickedxboi's Avatar
Default Re: Turbo timer install help....calling all 92-95 civics..... (highmilehatch2)
thanks guys.....i got it working
Old Apr 9, 2003 | 10:46 AM
civicgsr's Avatar
How did that link not help? The apex wiring is the same as the greddy wiring. Colors too.
Old Oct 24, 2003 | 01:56 PM
luti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highmilehatch2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, here goes: from the timer harness green, that goes to the yellow wire, red goes to the big fat white wire, (there are two white wires you need the fatter one), the blue wire goes to the black wire with the yellow stripe, black to ground! You have to cut the black plastic wrap that surrounds these wires to get to them.</TD></TR></TABLE>
According to the APEX website the black must connect to a specific ground, but when I have it attached to that one the timer only stays on (and therefore only works) when the key is in 1 click, I cant get it to stay on when I turn the key all the way back to take it out. Would this be fixed if I connected the black to the chassis?
HamiltonRex
14
Aug 9, 2006 06:07 PM
acuragtr
Aug 8, 2004 04:47 PM
pip9
May 29, 2004 08:33 AM
kholmes
Apr 19, 2004 04:54 PM
Flamenco-T
Nov 6, 2001 06:54 AM
