Airbag removal
Old Mar 21, 2003 | 07:14 PM
UndergroundVR-4's Avatar
Default Airbag removal
My 95 dx steering wheel is in bad shape with little dye left on it. I assume the easiest way to fix this is to replace the steering wheel, rather then dye it. How do I swap the airbag to another oem wheel?
Old Mar 21, 2003 | 09:10 PM
FULLTHROTTLE's Avatar
Default Re: Airbag removal (UndergroundVR-4)
1. remove battery cables.
2. remove little panel on bottom of steering wheel (should have 2 phillips screws in it)
3. unplug airbag yellow conector
4. remove two side panels on back of steering wheel
5. remove TORX bolts from airbag assy. and pull bag off stock wheel
6. remove stock wheel by removing 19mm nut and slowly pulling wheel.(Note: some wheels stick so its a good idea to put the nut back on a few turns to keep wheel from "popping" of and breaking oyur nose. *trust me on this*)
7. install new wheel and airbag in reverse order, plug in air bag last and then reattach battery cables.
[Modified by FULLTHROTTLE, 10:10 PM 3/21/2003]
Old Mar 22, 2003 | 07:40 AM
Default Re: Airbag removal (FULLTHROTTLE)
Thank you VERY much.
Old Mar 22, 2003 | 07:57 AM
GZERO's Avatar
WAIT 10 mins before unplugging the Air bag, they have a 10 min battery.
Old Mar 22, 2003 | 07:58 AM
Indiana Jones's Avatar
Default Re: Airbag removal (GZERO)
I hear its 2 hrs. . . . . wait 2 hrs!!!! lmao
Old Mar 22, 2003 | 07:59 AM
Default Re: Airbag removal (NA Gen2Teg)
Jk
Old Mar 22, 2003 | 09:57 AM
Chiovnidca's Avatar
I takes about three minutes for the capacitors in the SRS control unit to discharge. So wait at least three minutes.
htwitr01
Jul 8, 2010 07:13 PM
niceprelude
Dec 11, 2008 05:05 AM
DC5mike
Jan 12, 2008 08:15 PM
Jdmdc4ls
Apr 24, 2006 12:15 PM
TegoDC5
Dec 15, 2004 05:53 PM
