ABS light
Old Mar 21, 2003 | 04:03 PM
avs's Avatar
avs
Default ABS light
My ABS light's on for my Integra. I got a 4-8 code which is the rearwheel driver side wheel speed sensor. What do i need to replace ? The wheelbearing and the sensor or just the sensor alone? and how much would that run me.
[Modified by avs, 8:03 PM 3/21/2003]
Old Mar 21, 2003 | 04:37 PM
Chiovnidca's Avatar
Default Re: ABS light (avs)
You may want to check the resistance of the sensor to be sure that is the problem. I don't know the spec on those.
Old Mar 21, 2003 | 08:53 PM
avs's Avatar
avs
Default Re: ABS light (TurboD16Chiovnidca)
do u have a diagram or pic of the sensor? if the wire is shot do i need to replace the line? what kind of work is involve?
Old Mar 22, 2003 | 03:29 AM
Chiovnidca's Avatar
No, I dont have a pic. Just follow the wires till you get to a connector and measure it there.
Old Mar 22, 2003 | 05:04 AM
VTI_VTEC's Avatar
as far as i know the resistance should be about 1000 oham ,it was that not hard to change on a eg9 ,just trace the the wire from the speed sensor to a plug and disconnected and install a new speed sensor
kenny
KKRIS
Aug 28, 2012 08:19 PM
Bnjmn
Sep 9, 2003 01:25 PM
Bnjmn
suzuki99
Dec 28, 2001 07:49 PM
