injector voltage???
Old Mar 21, 2003 | 02:56 PM
GOLDBERG's Avatar
Default injector voltage???
with the ignition turned to ON, i get 12v on both wires..is this good or bad??my car still does not start up...
Old Mar 21, 2003 | 03:53 PM
toolbox's Avatar
Default Re: injector voltage??? (GOLDBERG)
Is the connector still plugged in when you are probing the wires?
Old Mar 21, 2003 | 03:54 PM
GOLDBERG's Avatar
Default Re: injector voltage??? (toolbox)
injector clips??yes
Old Mar 25, 2003 | 09:12 AM
JimBlake's Avatar
I don't have the wiring diagram with me now, so I might be confused...
The main relay supplies 12v to the injectors continuously. The ECU makes & breaks the connection to ground when it wants to fire them. So, if the ECU is NOT firing the injectors, you'll see 12v at both pins.
Old Mar 25, 2003 | 11:07 AM
Perfectionist's Avatar
Default Re: injector voltage??? (JimBlake)
[QUOTE The ECU makes & breaks the connection to ground when it wants to fire them. So, if the ECU is NOT firing the injectors, you'll see 12v at both pins.
[/QUOTE]
This is correct.
Old Mar 25, 2003 | 11:25 AM
GOLDBERG's Avatar
Default Re: injector voltage??? (Perfectionist)
cool so if i have ignition turned too on, i should see 12v at both, correct?
Old Mar 25, 2003 | 03:19 PM
Chiovnidca's Avatar
With the plug disconected, it should have voltage at one wire only.
salemned
Sep 7, 2017 12:13 PM
chrysanderson
14
Nov 7, 2010 09:08 PM
BfromSD
Jan 24, 2008 05:50 PM
Deo
Jan 24, 2008 06:31 AM
Hondatec38
Mar 4, 2003 08:57 PM
