what do u guys think of my B20 setup
Old Mar 21, 2003 | 11:54 AM
krazykid's Avatar
Default what do u guys think of my B20 setup
-b20 block w/ je 11.8 pistons, probe rods, balancing and micropolishing of crank
-b16 head with jun valvetrain, jun 3 cams, stock b16 valve, hondata
-type r manifold w/ rc 310 injectors, fuel reg and walbro fuel pump
-y1 w/ lsd tranny and a 6 puck act clutch with a heavy duty pressure plate
-bfgoodrich geforce tires on a 88 crx hf
-mad engineering mounts with stock axels though
what do u guys think do i need anything else cause i havent driven it yet cause i havent finished yet i need some other stock parts
Old Mar 21, 2003 | 11:57 AM
Jeff C's Avatar
Default Re: what do u guys think of my B20 setup (B20Demon)
Sounds beefy! You might consider a nice port and polish job too.
What header?
Old Mar 21, 2003 | 01:02 PM
wm5holla's Avatar
Default Re: what do u guys think of my B20 setup (Jeff C)
real good! you going all motor?
Old Mar 21, 2003 | 01:07 PM
Kamin's Avatar
Default Re: what do u guys think of my B20 setup (wm5holla)
with 11.8:1 compression ratio
do you even have to ask?
Old Mar 21, 2003 | 01:15 PM
TimoneX's Avatar
New User
I think you can safely assume he's going all motor w/ 11.8:1 and those cams.
Sounds pretty spiffy bro...let us know what kinda power you get.
Old Mar 21, 2003 | 01:17 PM
AllmotorJunkie's Avatar
Default Re: what do u guys think of my B20 setup (TimoneX)
Monster setup! I like it alot!!!
Good Luck getting all that power to the ground...
Peace
Old Mar 21, 2003 | 01:21 PM
joe_bocc's Avatar
Default Re: what do u guys think of my B20 setup (AllmotorJunkie)
Every thing looks good!
If it were me though, I would have went with the lighter ITR valves, but thats just me.
BTW, you got any dyno sheets?
Old Mar 23, 2003 | 11:40 PM
NightHawkC5's Avatar
Default Re: what do u guys think of my B20 setup (joe_bocc)
[Modified by NightHawkC5, 8:45 AM 3/24/2003]
Old Mar 23, 2003 | 11:43 PM
krazykid's Avatar
Default Re: what do u guys think of my B20 setup (NightHawkC5)
im running a DC 4 to 1 w/ a 2 1/2 inch collector running to 2/12 inch piping all the way back. port and polish is a litle out of my budget right now but will consider it. stumped on what tires to get though thinking of BFG geforce and maybe some slicks for the thight competition. let me know of anything else
Old Mar 24, 2003 | 12:41 AM
WundedSaint's Avatar
All that nice mechanical stuff...but what about fuel management? If it's a daily driven street car you need it, if not then who cares...heheh
I don't think you really need 310 cc injectors, proper fuel management would be better.
Old Mar 24, 2003 | 08:51 AM
krazykid's Avatar
Default Re: what do u guys think of my B20 setup (WundedSaint)
wouldnt hondata take care of that
Old Mar 24, 2003 | 09:02 AM
LS-hatch's Avatar
yes, hondata will be a very good investment for your build. If you do a search (top right) there are plenty of archived posts about why to use hondata etc. Very informative stuff in there.
Old Mar 24, 2003 | 09:10 AM
acura_typer's Avatar
Banned
hmm, 310s may be enough, but i get to 80% duty on My b20 vtec 450cc injectorswith just ctr cams....
Old Mar 24, 2003 | 09:36 AM
Jeff C's Avatar
You will optimize the power potential of your cams with a good p&p job. Seriously think about it.
Old Mar 24, 2003 | 08:17 PM
krazykid's Avatar
how much does port and polish usually go for and where does a place do it for cheap
Old Mar 26, 2003 | 05:40 AM
GM2000ITR's Avatar
New User
Port & polish should definitely be added to your list. Everything else sounds like a decent setup. Although, MY OPINION is that the clutch/P.P. combo may be overkill, but it's your setup. Good job, though!
Old Mar 26, 2003 | 09:05 AM
All Motor Rex's Avatar
Port & Polish prices range depending on what you are looking for and where you go. This is not something that you want to send to someplace that does it "cheap" A lot of (if not most) of the power is made in the head. If you can't afford to send someplace for good head work, then my suggestion would be to save your money and do it later. Check out http://www.dprracing.com when you want to do it. Dan does great work, and will take care of your needs.
You might want to consider a different header too. I would suggest SMSP or Hytech, but it sounds like you are on a bit running low on cash, so you may want to go with a JG or AN-R.
Just my .10cents.. Good Luck!
Old Mar 26, 2003 | 09:25 AM
iH8BiTeRz's Avatar
Default Re: what do u guys think of my B20 setup (acura_typer)
WHAT? What do you have for fuel pressure / fuel pump? No way you should be hitting 80% with 450cc injectors if you just got cams!
Old Mar 27, 2003 | 11:47 AM
TimoneX's Avatar
New User
Default Re: what do u guys think of my B20 setup (iH8BiTeRz)
Depends on how high he's revving it as well as fuel pressure. These engines get thirsty at high RPMs.
silver vtec
15
Jun 17, 2006 03:45 AM
BuBBa y0!
11
Feb 9, 2004 08:20 PM
Demolition Man
Jul 23, 2002 03:36 AM
xJ.SLOTHx
Aug 23, 2001 12:02 PM
