Should I port/polish intake manifold?
Old Mar 21, 2003 | 09:50 AM
serequis's Avatar
Default Should I port/polish intake manifold?
I just sent out my B16 cylinder head out to get ported and polished. Should I also send out my intake manifold and throttle body?
My application is NA.
Old Mar 21, 2003 | 10:19 AM
sgT's Avatar
sgT
Default Re: Should I port/polish intake manifold? (serequis)
no.
Old Mar 21, 2003 | 10:25 AM
All Motor Rex's Avatar
You don't need to port & polish the manifold per se, but I would make sure that the throttle body and intake mani, are the same size diameter. Also may want to match the ports on the head w/ the manifold.
Good Luck.
Old Mar 21, 2003 | 12:50 PM
dfoxengr's Avatar
Default Re: Should I port/polish intake manifold? (sgT)
no port matching ur IM in many cases actually screws up the air flow, making you lose power...wrong shape and dynamics
Old Mar 21, 2003 | 12:53 PM
.RTErnie's Avatar
Default Re: Should I port/polish intake manifold? (hybridvteceg)
Yes and no....
If you dont know what your doing and dont have the proper tools/knowledge then no.
you'll have to wait for the head for port shapes/sizes. If they gasket matched the cylinder head it will be easy. If not Id leave it alone.
Get a die grinder and a non-ferrous bit. Rounded with a slight point. get some aluminum cutting fluid, cross buffs, and a flap wheel. Have fun Just dont go to big and blend the transition further down the runners.
Old Mar 21, 2003 | 01:21 PM
AllmotorJunkie's Avatar
I would depending on the person or shop doing the porting. I am having my IM match ported to my head as we speak. I'll post something about the power gain/losses after installation.
Peace.
Old Mar 21, 2003 | 01:22 PM
sgT's Avatar
sgT
Default Re: Should I port/polish intake manifold? (AllmotorJunkie)
generally
you want the tb opening to be slightly smaller than the IM opening
and you want the ports in the manifold smaller than the ports in the head
Old Mar 21, 2003 | 01:26 PM
joe_bocc's Avatar
generally
Would this, by any chance, be for good anti-reversion air flow? I've heard that this is the best way to go.
Old Mar 21, 2003 | 01:27 PM
sgT's Avatar
sgT
Default Re: Should I port/polish intake manifold? (joe_bocc)
anti reversion yes
Old Mar 24, 2003 | 09:36 PM
.RTErnie's Avatar
Wouldn't it be better just to do it right the first time? And port "MATCH" them
Old Mar 25, 2003 | 11:52 AM
H22coupe's Avatar
Default Re: Should I port/polish intake manifold? (RTErnie)
Anyone have a good answer on this question? I"m about to send my head out for some mild posrt and polish work to go along with my new valvetrain.
Old Mar 26, 2003 | 06:53 AM
Charlie Moua's Avatar
generally
so what is a good "rule of thumb" to go by?
should it be about 1mm or like 2mm?
Old Mar 26, 2003 | 07:01 AM
rustyeleio's Avatar
I have read that port matching is good, removing all the casting remnant crap is good but polishing the intake is bad. This is because the roughness is supposed to create turbulence in the air flow which is supposed to help with fuel/air mixing.
Old Apr 2, 2003 | 11:21 AM
.RTErnie's Avatar
Default Re: Should I port/polish intake manifold? (rustyeleio)
hmmmm. since we have injectors for that.... and portflow polishes the **** out of their heads....why not?
Old Apr 2, 2003 | 11:44 AM
turbo*s2k's Avatar
Can you tell me how you packed the head to get shipped out, who you sent it through, and what was the cost? I'm just curious. I'm going to be sending my head to portflow. I would like to ship it, but it might be better to just drive there. There about 5 hours away from me.
Old Apr 2, 2003 | 02:00 PM
evo's Avatar
evo
New User
If its OK if the IM a bit bigger than the head??
Old Apr 2, 2003 | 03:58 PM
dfoxengr's Avatar
Default Re: Should I port/polish intake manifold? (evo)
what u said makes no sense...
Old Apr 2, 2003 | 06:04 PM
HEAD's Avatar
I wouldn't worry about the gasket matching because the gasket on the head matches up pretty good and you are going to want the manifold a little smaller to help reversion like it was stated earlier. In my opinion the area behind the throttle body is were the work is needed, not alot though there are just some sharp edges that I take out and and I think some of the casting flash could be smoothed on the head side of the manifold but I wouldn't say any of this had to be done, I don't think it's worth any power but if you have the money and are crazy about little details like me go for it.
Old Apr 2, 2003 | 09:40 PM
EKhatch's Avatar
What plenum are you talking about? If you are talking about the stock B16 plenum then you may want to think about picking up another plenum instead of paying someone to do portwork on the stock one depending on how much the person you are thinking of sending it to is going to charge you. It would probably be more benaficial to pick up an aftermarket plenum that has better casting (on the inside) that is not as disruptive when it comes to a smooth air flow through the inside of the plenum. The inside of a stock B16 plenum is quite rough and you would have to do spend a fair amount of money getting it worked on to get decent improvements.
Old Apr 2, 2003 | 09:44 PM
Neukin's Avatar
Default Re: Should I port/polish intake manifold? (EKhatch)
just do it, im sure it wont make in any slower, just faster and thats all that matters...
go to dh-racing.com they do a thing where you give them your and they give you one of theirs that all done. like $200 or 2 sad speeding tickets
[Modified by toyosupr, 1:47 AM 4/3/2003]
TwitchDa9
Mar 18, 2011 12:40 PM
airmaxbri
Feb 26, 2010 09:05 AM
ShawnR
Apr 9, 2007 11:22 AM
Crono139
10
Jun 1, 2006 09:49 AM
turboman
Apr 7, 2004 06:39 PM
