Greddy Type S BOV Adjusting Nut?
Hey guys, I was just washing my engine bay today, then I realized my BOV has someting wrong
the adjusting nut is gone?? is there one on the top??
any body has a close picture Please??
If there should be a nut, where would I be able to get it??
thank you
thank you
i need to adjust the middle part, right??
once i loosen the nut, i can adjust that, right??
hmm.....
I will try to adjust it now
thanks
hmm.....
thanks
You want it just tight enough so that it doesnt leak pressure under boost.
(which isnt very tight at all, if your running low boost).
The looser it is, the quicker it will be able to open and release pressure when you let
off the gas. If its too tight, it will allow a pressure spike to build up for a split
second before it opens. I guess you can imagine that having a pressure spike is not good
For example: if you take the BOV off, you can press the plunger open by hand with a little effort. You want it just loose enough so that the 10psi(or whatever) of boost your running
can't push it open.
[Modified by rioninja, 11:27 PM 3/21/2003]
can't push it open.
B16Civic93
Mar 8, 2005 07:36 AM
