quick valve lash Q
Old Mar 21, 2003 | 08:45 AM
khoalie's Avatar
Default quick valve lash Q
Can't seem to get a solid answer.
When you lash valves does it matter whether you put your feeler between the valve and the rocker or rocker and cam.
It seems doin it on the cam would be more accurate because the valve stem would wear a little dip in the rocker and that would throw off the measurement making all your valves loose.
Does anyone know what i am talking about?
TIA
[Modified by khoalie, 11:45 AM 3/21/2003]
Old Mar 21, 2003 | 09:45 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: quick valve lash Q (khoalie)
I have always done it on the cam. I believe that's what it says in the Service Manual as well.
Old Mar 21, 2003 | 10:41 AM
orange.honda's Avatar
Default Re: quick valve lash Q (shamoo)
i have always done it between the valve and rocker arm. thats how they taught me in school.
Old Mar 23, 2003 | 08:15 PM
khoalie's Avatar
damn thats going to be a biatch on a d series
any tips on getting that damn blade in there?
Old Mar 24, 2003 | 05:05 AM
b19coupe's Avatar
On B-series motors, I put the feeler guage between the cam and rocker. On D and F series motors, between the valve and rocker arm. It depends on the design of the cylinder head, as to where to put the feeler guage.
Old Mar 24, 2003 | 06:11 AM
EVIL_AWD's Avatar
Default Re: quick valve lash Q (b19coupe)
B19coupe stated it perfectly!
Old Mar 25, 2003 | 10:22 AM
JimBlake's Avatar
Default Re: quick valve lash Q (ITR420)
It all depends on the clearance that's published. In principle you can measure it either place, but the actual clearance will be different. When you read the spec. clearance, you have to know which location they mean.
If its difficult to get a feeler gauge on the valve stem, then they publish the clearance at the cam lobe. Read the procedure in your shop manual, not just the clearance numbers.
Old Mar 25, 2003 | 03:25 PM
Chiovnidca's Avatar
Put the feeler guage between the cam and rocker on H-series also.
RacerJ
Engine Machining & Assembly
Jun 15, 2018 11:17 PM
CRX Lee
Aug 5, 2005 08:51 AM
SpoogenJay
Aug 9, 2003 01:37 PM
95gsr
Apr 8, 2003 07:20 AM
Cow
Jun 26, 2002 04:12 PM
