Crazy Idea..........Turbo Questions.............
My work has a junked 1984 Nissan pulsar Turbo.......would it be possible to put this turbo on a 1984 CRX?
Crazy Idea I know, but the turbo would be free if it works.......Let me know....
you can put basically any turbo on anything...basically...
thats called junkyard turbo setup, will work just need to make custom piping and manifold etc.
with patience and some $$ u can do ANYTHING, but junkyard turbos are pretty easy to do....search around here. Lots of info.
Good luck if you decide to do it!
mike
mike
Thanks for your help, but I heard that turbos are hard to take care of......will they beat up engines? Cut their life span?
Well turbo requires a little more attention to your motor. You need to keep up on the oil changes and regular maintenance. It does take some time and money.. but you will be very happy with a turbo motor.. believe me ive seen it many times.. but like i said it takes time.. you need to gather the right parts.. i.e turbo, wastegate, manifold, piping, intercooler, fmu.. etc... good luck.. let us know how it goes
Anything that puts more power into an engine will decrease the life, but the torque is worth it I think. Remember that the most important part of a turbo system is the fuel management. Putting the right amount of fuel witht he right amount of air will prevent knock (detonation), which is what will bring the life of your engine to a very quick end.
P.S. To learn everythig you ever wanted to know about turbos, read Corky bell's book, <U>Maximum Boost</U>
[Modified by Draco, 9:18 PM 3/29/2003]
1000kg88hb
Mar 12, 2007 01:01 PM
