wtf did i get the wrong pins?
Old Mar 20, 2003 | 06:30 PM
altoid's Avatar
Default wtf did i get the wrong pins?
i got my pins for my pm7 pistons a while ago, i decided to check them out, and the pins just slide right into the piston without a problem. no force. gravity just takes them in side of the piston and out the other. is this suppose to happen? Does the pin get pressed into the rod and thats the only thing holding the pin there? I guess it is. I've actually never bothered looking at the pin/pistons setup and how it works. Any insight would be great. thanks
Old Mar 20, 2003 | 07:06 PM
TREVER's Avatar
Default Re: wtf did i get the wrong pins? (altoid)
they press into the rod and float on the piston
Old Mar 20, 2003 | 07:07 PM
dfoxengr's Avatar
do you have stock rods?
Old Mar 20, 2003 | 07:52 PM
altoid's Avatar
Default Re: wtf did i get the wrong pins? (hybridvteceg)
yeah they're chilling in my engine right now. The manual said all pins are oversized when bought w/out them in the engine, so the rod should still press into them if thats what you're pondering
[Modified by altoid, 11:55 PM 3/20/2003]
Old Mar 21, 2003 | 07:41 AM
EKhatch's Avatar
Default Re: wtf did i get the wrong pins? (TREVER)
With stock rods.
eg6madness
Apr 19, 2007 06:02 PM
Yuleluder
Feb 15, 2006 05:14 AM
jakscivic
Jan 13, 2006 02:48 PM
SOHCD16y8
May 20, 2005 10:34 PM
CRX Lee
Feb 9, 2004 08:39 AM
