What does 'intialize' on an S-AFC do?
Old Mar 20, 2003 | 06:16 PM
Westrock2000's Avatar
Default What does 'intialize' on an S-AFC do?
Just saw that option in the [etc.] menu, and didn't know what it did. Is it maybe a reset button?
Thanks
Old Mar 20, 2003 | 06:18 PM
quis23's Avatar
Default Re: What does 'intialize' on an S-AFC do? (Westrock2000)
push it and see
yeah its the reset button.
Old Mar 20, 2003 | 06:21 PM
Default Re: What does 'intialize' on an S-AFC do? (quis23)
Does it just reset everything, or do I need to do that whenever I make changes?
Also does anyone know why on the AFC when it shows correction levels, and say you have it set to +6%, it says +6% at 0% throttle, but as you give it gas it starts to decrease like to 5.6%.
Old Mar 20, 2003 | 07:14 PM
dfoxengr's Avatar
it initializes everything...
gets it ready IE starts over
Old Mar 20, 2003 | 09:28 PM
shamoo's Avatar
Will you make something up for me please?
Well...think about this if you have this setting:
10% at 1000rpm
15% at 2000rpm
And so on....
If you have your rpm's somewhere in between that, it'll obviously have correction somewhere between 10% and 15%, right? I'm not entirely sure what you're getting at, but the AFC will interpolate what setting it should be at given a certain rpm and throttle position.
Also remember, you have a HI-throttle and LO-throttle fuel correction based on RPM. You might have them set at different points, which you should. (Unless you're one of those crazy turbo guys running the AFC-Hack )
Old Mar 22, 2003 | 04:28 AM
Default Re: What does 'intialize' on an S-AFC do? (shamoo)
ahhh....good point about the hi-lo thing....I didn't think about it dithering from one to the other.
projectTeG
Aug 2, 2009 10:05 AM
builthatch
Aug 16, 2005 07:37 PM
builthatch
Aug 15, 2005 05:29 PM
niedejb
Mar 18, 2003 01:23 PM
Speed PHreak
Aug 29, 2001 07:30 AM
