What cams for fully built LS?
Old Mar 20, 2003 | 11:24 AM
93LSivic's Avatar
Default What cams for fully built LS?
Havent got off my *** to research which cams to use. This is goin on my fully built LS daily driver. I dont really mind an 1100 rpm idle.
I know a couple guys have the Web cams that boosted3g designed (speedfreak). Who had luck with the crower's?
Im gonna be making well over 400 whp.
Old Mar 20, 2003 | 02:08 PM
TeStUdO's Avatar
Default Re: What cams for fully built LS? (93LSivic)
how about the tried and true gsr cams???? cheap and effective
Old Mar 20, 2003 | 02:17 PM
boostaholic's Avatar
Default Re: What cams for fully built LS? (00si5)
keyword, LS head.
Old Mar 20, 2003 | 02:18 PM
TeStUdO's Avatar
Default Re: What cams for fully built LS? (boostaholic)
sorry didnt see that , then definitely some crower or the skunk2 turbo ones
Old Mar 20, 2003 | 02:19 PM
b18bturbo's Avatar
Contact the guys at Zex they have some new cams they were coming out with when i talked to them really good turbo cams. Other than that your only other choice would be the Crower.
Old Mar 20, 2003 | 03:40 PM
TurboTegB18c's Avatar
Default Re: What cams for fully built LS? (b18bturbo)
Ef-1 cams will be available pretty soon. Another one of rocket's creations.
Old Mar 20, 2003 | 04:02 PM
TurBoTeG's Avatar
Default Re: What cams for fully built LS? (TurboD16Z6)
im in the same boat...i think i might end up with a custom grind
Old Mar 20, 2003 | 04:05 PM
turbospool's Avatar
Default Re: What cams for fully built LS? (TurBoTeG)
ever heard of JG 1001?
Old Mar 20, 2003 | 04:08 PM
94dxt's Avatar
Default Re: What cams for fully built LS? (turbospool)
Skunk 2 makes good stuff but the thing they suck @ making are Cams
Old Mar 20, 2003 | 05:12 PM
DIRep972's Avatar
Smarter than you
stock LS cams are 220/222 advertised duration w/ .395(10.03mm) / .380(9.65mm) lift.
I would prefer something w/ 230 or so duration and maybe 10.7-8mm lift. I did a little research awhile back on a few cams ill see if I can find some stuff again. but basically I was looking for something that would pull about 1k rpm's longer and not loose the natural torque curve of the LS. I know someone w/ like an 11.9mm lift cam on there LS and a 60-1 turbo, they said it is a BITCH to tune when boost comes on.
Old Mar 20, 2003 | 06:41 PM
lsturbo's Avatar
i would go with the crower 402Turbo cams
Old Mar 20, 2003 | 10:36 PM
JalopySiR's Avatar
Default Re: What cams for fully built LS? (DIRep)
I would consider the EF-1 cams (small grind) from Rocket for your LS. I have them in my NA setup and they are awesome, I gained about 15WHP after tuning w/ afc and cam gears(on a B20). The duration is bigger than what you specified, but Rocket knows his ****. As soon as I can finish up my turbo kit, I should have some dyno numbers. If you talk to him, tell him JalopySiR sent you!
Old Mar 21, 2003 | 12:22 AM
Sonny's Avatar
Default Re: What cams for fully built LS? (JalopySiR)
Rocket
I'm going to use the L21 LS cams in my D16A1/ZC. I'm not going to use the actual LS cam set (they don't fit), but the same grind is available for the ZC. They can make new ones or regrind existing cores for ~200. Using a regrind seems to be a little more "tricky" in a VTEC head, but people have done it for a long time on the non-VTEC SOHC and DOHC heads.
Maybe the Skunk2 or Crower cams are better...maybe not. One thing that is for certain is that you will not beat Rocket's customer service or willingness to work with you.
Sonny
[Modified by Sonny, 1:23 AM 3/21/2003]
Old Mar 21, 2003 | 06:15 AM
93LSivic's Avatar
Default Re: What cams for fully built LS? (Sonny)
I have considered Rockets cams. We are a dealer for him. I havent had a chance to talk to him since Ive been busy at work.
Anyone else have some more suggestions?
Viren, I will look into the ZEX cams--thanks.
Old Mar 21, 2003 | 06:39 AM
b18bturbo's Avatar
the zex gsr cams is what i am gonna try out this year in the ls vtec setup i got set free so we can see whats up.. we really need to challenge like the manifold to get a true understanding of what works and what doesnt.
IT will help the honda community here at least alot.. i am willing to dyno and try different things so just let me know we can start messing with them
Old Mar 21, 2003 | 07:01 AM
93LSivic's Avatar
Sounds good to me. I would be willing to dyno a couple different ones since now we have a couple dyno's popping up in our area here.
I gotta call one of our rep's that carry zex and see what they offer spec wise, and price wise. I know lots of poeple have good luck with their sohc nonvtec cams.
bigbadboy
Jul 26, 2007 07:32 AM
All Day
Jun 19, 2004 07:40 PM
JCracer723
Sep 8, 2002 06:07 PM
4U2NV
Jan 14, 2002 07:42 PM
