Need to convert my 89 JDM SiR to 0bd1!
Old Mar 20, 2003 | 02:50 AM
markleavey's Avatar
Default Need to convert my 89 JDM SiR to 0bd1!
Hi guys,
I need to rewire my JDM EF8 to OBD1 in order to use a Hondata system and P28 ECU with my JDM ITR motor. Has anybody done anything similar? Can anyone give any advice?
Thanks in advance
Mark
Old Mar 20, 2003 | 06:21 AM
red civic standard's Avatar
Default Re: Need to convert my 89 JDM SiR to 0bd1! (markleavey)
buy an OBD0 to OBD1 conversion harness from Blown90hatch on this board.
You can use the stock OBD2 ITR distributor and injectors and just run them OBD1.
If you don't have OBD1 or OBD2 distributor, injectors, o2 sensor already, then you will have to buy these.
I'm trying the same setup.
[Modified by red civic standard, 7:22 AM 3/20/2003]
Old Mar 20, 2003 | 07:47 AM
markleavey's Avatar
Default Re: Need to convert my 89 JDM SiR to 0bd1! (red civic standard)
Thanks for the info Red Civic Standard. Have you any idea how much Blown90hatch sells them for? Im in the UK so I will need to get it shipped.
The ITR motor is complete with distributer, injectors etc.
Which o2 sensor do you mean?
Mark
Old Mar 20, 2003 | 08:58 AM
use the o2 sensor that came on your swap (a 4 wire sensor). Blown90hatch sells them from around $150 to $170.
lilmarcEH3
19
Jan 4, 2010 08:18 PM
BI8B
Nov 21, 2003 02:33 PM
5 Skware
Jul 30, 2003 04:32 AM
qqqq
Apr 8, 2003 07:53 PM
Quick 200k Mile Motor
13
Jul 25, 2002 09:11 AM
