tranny fluid for jdm b16???
Old Mar 19, 2003 | 11:02 PM
4inspeed's Avatar
Default tranny fluid for jdm b16???
ok dont talk crap cause i already did a search and i didnt find anything. i have a b16 and i was wonderin what fluid to use for my tranny, i want to know good stuff not just stuff that will be "ok" so if anyone has any sugestions please help?
Old Mar 19, 2003 | 11:07 PM
mr. wu's Avatar
Default Re: tranny fluid for jdm b16??? (4inspeed)
usally just regular 10-30 will work fine, unless you have an lsd then you shoul run something made for the lsd like redline fluid
Old Mar 20, 2003 | 06:09 AM
REDBARON's Avatar
Default Re: tranny fluid for jdm b16??? (mr. wu)
I only use Honda MTF. It's the best in my mind. I would stay away from 10-30
Old Mar 20, 2003 | 06:14 AM
ElementMotor's Avatar
Default Re: tranny fluid for jdm b16??? (REDBARON)
Old Mar 20, 2003 | 09:53 AM
HybridFiend's Avatar
Default Re: tranny fluid for jdm b16??? (EF8 ownz u)
Yes, in all Honda Helms service manuals that I have seen, say that any 10-30 is only for temporary use until you can use Honda MTF. There are additives in the Honda MTF that are designed for the syncronyzers, seals, and o-rings. Kinda like how the Power steering fluid is for the Power steering system!
Old Mar 20, 2003 | 10:51 AM
Bseries's Avatar
I have used both engine oil and honda MTF and redline and do not notice a difference in shifting at all. if you have hard shifting then trans oil type is probably not your problem.
Old Mar 20, 2003 | 10:56 AM
RCautoworks's Avatar
Default Re: tranny fluid for jdm b16??? (Bseries)
I only use honda manual transmission fluid. By the way, here is the link that someone asked the same question 2 days ago.
https://honda-tech.com/zerothread?id=446893
[Modified by 90blackcrx, 1:57 PM 3/20/2003]
Old Mar 20, 2003 | 11:02 AM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: tranny fluid for jdm b16??? (90blackcrx)
Here is more on the subject from a few more days ago.............
https://honda-tech.com/zerothread?id=440999
Lsos's Avatar
I had a 3rd gear gring in my Y1 tranny. I put in some Honda MTL, and the grind went away.
Old Mar 20, 2003 | 11:03 AM
Driven's Avatar
I use 10w30 in my tranny. The tranny has always had a grind from second-third shift...it just got progressively worse... but, it's largely due to the 5000miles of racing placed on it.
dohcgarage@714
Honda S2000
11
Sep 12, 2008 01:39 PM
tallblondkid
Aug 18, 2004 03:59 PM
JDMCRX
Jun 5, 2004 08:46 PM
bluecrxsi
16
Apr 14, 2003 01:06 PM
rig9896
Oct 18, 2002 04:45 AM
