Removing Clutch and flywheel
Old Mar 19, 2003 | 06:52 PM
civcexcoupeblack's Avatar
Default Removing Clutch and flywheel
I have a b18b. I have taken off the tranny, and now I need to remove the flywheel and clutch. I tried taking the star shaped bolts off, but the 11 mm socket started slipping around. How do I take this stuff off?
Old Mar 19, 2003 | 06:54 PM
Dan GSR's Avatar
Default Re: Removing Clutch and flywheel (civcexcoupeblack)
you using 12pt socket?
if memory serves me its 10mm not 11
your probably using 6point socket...what you need is a 12 point socket
Old Mar 19, 2003 | 07:22 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Removing Clutch and flywheel (Dan GSR)
Yes, he got it right...make sure you use a 12pt socket. Don't strip those suckers
Old Mar 19, 2003 | 07:29 PM
Default Re: Removing Clutch and flywheel (shamoo)
is it 10mm or 11 mm?
Old Mar 19, 2003 | 07:31 PM
Dan GSR's Avatar
10mm
I don't recall using 11m on anything
Old Mar 19, 2003 | 08:20 PM
jonoknut's Avatar
make sure you dont strip that thing, then you could be knee deep in donkey ****!
jon
Old Mar 19, 2003 | 09:22 PM
Volcom's Avatar
When I replaced my clutch a month and a half ago, I had part of the clutch disc broken and rubbing on those bolts. Basically, that was the only piece of material engaging the clutch and no wonder why I had such bad clutch chatter . I would say that I lost about half of the material on those bolts. Good luck
cletus11
Jan 7, 2012 12:07 PM
GSR_hatch936
37
Nov 1, 2007 06:21 PM
flip1199
Nov 7, 2005 11:07 AM
snatch
16
Aug 11, 2004 08:16 PM
integraautox
Jan 23, 2003 01:14 PM
