removing tranny - someone really needs to tell me these things...
Old Mar 19, 2003 | 05:10 PM
serious's Avatar
Default removing tranny - someone really needs to tell me these things...
i'm reading through my helms, and it looks like you don't have to take the axle nut off to remove the engine and transmission. is this correct? if it is, someone should have told be sooner .
Old Mar 19, 2003 | 05:14 PM
Vinceg99's Avatar
Default Re: removing tranny - someone really needs to tell me these things... (serious)
Well you could probably get away with not taking them off even though it will be a big PITA. You will have to take everything apart like your taking out the axle (just not the axle nut) so there is enough play to pull the axles from the tranny.
Old Mar 19, 2003 | 05:19 PM
RenoRacing's Avatar
Default Re: removing tranny - someone really needs to tell me these things... (Vinceg99)
i did mine on sunday for the 3rd time and i didn't remove the axle nut at all. just take off the lower control arm crown nut at the bottom of the hub, the 17mm bolt that goes through the lower control arm and the strut, and undo the steering linkage crown nut and then you can swing the axle over the lower control arm and out of your way. on the passenger side you don't even have to remove the steering linkage because the axle is so short. I'd also recommend removing the passenger side radius rod, it makes it a lot easier to do everything.
JwithTHEek
Jan 13, 2010 10:32 AM
crx18c1
10
Apr 17, 2007 10:17 PM
B18CYAAA
Oct 25, 2006 02:29 PM
EFin' Kyle
Dec 13, 2005 10:29 PM
peshte
Oct 3, 2005 10:07 AM
