B20 into EK wiring woes part 2: B20 distributor connector plug into stock '96 EK harness?
Old Mar 19, 2003 | 04:06 PM
DevinW's Avatar
Default B20 into EK wiring woes part 2: B20 distributor connector plug into stock '96 EK harness?
Hi,
First some background: My '96 civic had a '92 d16z6 engine and tranny in it previously, using the stock civic wiring harness and an OBDII-OBDI conversion harness.
I am swapping an OBDII '99 B20Z into the car, using a P75 OBDI LS ecu. Does the wiring harness for a stock '96 civic have the right connector to plug into the B20 distributor? We can't find this connector on the '96 harness, and I fear the previous owner had changed the plug out for an OBDI plug.
If the above was the case, would it be possible to swap the connector with the one from the '99 B20 harness, so it'll plug into the B20 distributor...and is this a difficult thing to do?
Thanks for reading!
Old Mar 19, 2003 | 05:19 PM
spookhatch24's Avatar
Default Re: B20 into EK wiring woes part 2: B20 distributor connector plug into stock '96 EK harness? (Devin
yes it will plug into the distrubotr the only diffrence between 96-98 and 99^ is that the wire harness plugs are diffrent but u can get a conversion harness to fix that they are available at jdmhondaparts.com and yes u can just add in the connector u can just pin it in at the ecu if it's not there
Old Mar 19, 2003 | 07:07 PM
DevinW's Avatar
OK, thank you! Just making sure...
BoltonGSR
Jun 1, 2007 08:21 AM
BoltonGSR
May 23, 2007 07:59 AM
Smokinsax
May 4, 2004 09:01 AM
DevinW
Apr 7, 2003 10:29 AM
DevinW
Apr 7, 2003 04:08 AM
