AHHH!!! I broke something
Old Mar 19, 2003 | 10:41 AM
94Gizzer's Avatar
Default AHHH!!! I broke something
I was putting on my new valve cover. everything was fitting right, no problems. I began to screw down the four nuts that go on each of the inner four studs (the ones that hold the wire cover in place) and i broke the two on the left I tightened them too hard apparently, but they didnt even feel like they were that tight. anyways, i got the valve cover tightened enough so there isnt any leaking, but i want this fixed. should i do it myself - dont u have to take apart the hole head to do it? go to the dealer? cost?
Old Mar 19, 2003 | 10:47 AM
94TealGSR's Avatar
Default Re: AHHH!!! I broke something (94Gizzer)
One mine is broken too. Hasn't leaked yet... if it aint that broke.. don't fix it.
Old Mar 19, 2003 | 11:03 AM
VTECorona's Avatar
Default Re: AHHH!!! I broke something (94TealGSR)
That happened to me in august and I thought I was fucked too. You can buy the studs at acura and do it yourself, they're like 3-4 bucks a piece. Took me 5 minutes to do. All you need is a deep socket, 10 or 12mm
Old Mar 19, 2003 | 11:06 AM
94Gizzer's Avatar
Default Re: AHHH!!! I broke something (97RedTegGSR)
i was told that you had to take apart the head to replace those studs? the other problem is that when i broke one of the studs, the washer and nut kinda stayed with the part of the stud still attached to the engine. i cant get the valve cover back off now. geez, what did i do
Old Mar 19, 2003 | 11:12 AM
VTECorona's Avatar
Hmm.. Shitty. You don't have to take off the head, just the valve cover. Unscrew the stud from where you see it going into the head, it has a hex head on it, its either 10 or 12mm I'm not sure. You will need a deep socket to tighten the new one though.. Those nuts are a bitch to torque right, mine still get loose and I have to tighten them every now and then. I tighten them pretty tight each time too, my torque wrench doesnt go low enough for the recommended torque so I just hand tighten with a socket.
Old Mar 19, 2003 | 11:23 AM
shadowdawn's Avatar
People don't understand spec is like 12lbs of torque, Alot of people snap these because they aren't using torque wrenches.
Old Mar 19, 2003 | 07:35 PM
Rtzx9r's Avatar
GDD 1%
Default Re: AHHH!!! I broke something (shadowdawn)
A lot of people who actually do have a torque wrench own a 1/2" one, and it does not go that low.
And then there are those who do not know how tight to go on a bolt by feel. It comes with experience.
Old Mar 26, 2003 | 10:07 AM
94Gizzer's Avatar
Default Re: AHHH!!! I broke something (Rtzx9r)
i didnt want to break it again, had the acura dealer fix it. was $106, but it was done right.
ya live and ya learn i guess
[Modified by 94Gizzer, 11:07 AM 3/26/2003]
Chef Andre
Apr 3, 2008 08:11 PM
BDogggUT34
Apr 22, 2005 03:12 PM
Hybrid 350GT
Aug 29, 2004 01:20 PM
maderfacker
Aug 24, 2002 02:13 PM
vtec-outlaw
Feb 12, 2002 05:16 PM
