Cv Shaft Install help
Old Mar 19, 2003 | 09:50 AM
Gerst240's Avatar
Default Cv Shaft Install help
I had a cv shaft go bad in my beater 86 accord , so i got a new one pulled the old one out and put the new one in. I put all the suspension back together dropped the car to the floor and mtf started flowing out of the tranny. so i jacked the car back up again and pulled everything off and im back at puttin everything together i was wondering if there are any tricks to puttin them in ? and yes the little snap ring is still in place
and i did search
thanks
Old Mar 19, 2003 | 10:01 AM
tilt's Avatar
Default Re: Cv Shaft Install help (Gerst240)
which side are you talking about? The driver/half-shaft side should slide right in w/o much force. The passenger side needs a bit more force... I used a gear puller at the hub end to "push" the axle into the tranny. You might want to check your seals... might have torn them. hth.
Old Mar 19, 2003 | 10:03 AM
Gerst240's Avatar
Default Re: Cv Shaft Install help (tilt)
it is the driver side what seals are you talking about? it really isnt hard to get in /out its just that when i set it down i lost fluid
thanks for the quick response
Old Mar 19, 2003 | 10:07 AM
sgT's Avatar
sgT
maybe you tore the seal when you put the axle in
Old Mar 19, 2003 | 07:40 PM
Pengo's Avatar
Default Re: Cv Shaft Install help (sgT)
the snap rings went in all the way and the halfshafts stayed in the first time you put em back in rite? did you flush and refill ur mtf or just kept whatever was in there from before? may wanna look at the seal as others mentioned above
Voodoo7
Apr 2, 2012 01:17 AM
Zewbie
Sep 2, 2011 12:55 PM
ECKOTYPER
Apr 9, 2004 07:46 PM
96integra20
Feb 22, 2003 11:53 AM
Chrislow
Nov 8, 2002 11:07 AM
