how much can stock rods handle??????
Old Mar 19, 2003 | 09:41 AM
boostedinteg03's Avatar
Default how much can stock rods handle??????
I have a turbocharged b18b1 and am going to put 8.5:1 srp pistons in, but i dont have the money for rods so i was wondering how much hp the stock rods can handle. i am going to put arp rod bolts in the stock rods for alittle more strength. also how much boost should i be able to run with the right fuel tuning and that set up?
Old Mar 19, 2003 | 10:08 AM
Mase's Avatar
Default Re: how much can stock rods handle?????? (boostedinteg03)
if i were you, id work some extra hours, make some extra money to buy the rods, they arent that expensive, its a bitch to tear apart the motor if you arent gonna replace both the pistons and rods....
just my opinion though.....
the stock rods will handle 12 psi no problem daily
Old Mar 19, 2003 | 01:04 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: how much can stock rods handle?????? (Mase)
I would suggest spending a little bit more money and at least have your stcok rods shot peened. That should make them stronger.
-Will
Old Mar 19, 2003 | 01:21 PM
T-sohctec's Avatar
Default Re: how much can stock rods handle?????? (integra707)
stock B series rods will handle over 300WHP.....
But if your gonna have your bottom end opened up and all sorts of work done I would personally reccomend you get a second job for about a month.
Bottom line, it's not that much $ and you will cry like a little girl if they fail
Old Mar 19, 2003 | 01:36 PM
rioninja's Avatar
enough said.
LSiTurbo's Avatar
Default Re: how much can stock rods handle?????? (T-sohctec)
...i have heard over 300hp, it could be wise to temporarily just put pistonsin, cause all you have to do is hone the cylinder walls, and not mess with rod bearings. Machine shops charge alot to mess with bearings and finding someone to do it right(that you can trust) can be a pain in the ***. You should be able install pistons in your garage but not the rods, thus saving yourself alot of labor money!
Old Mar 19, 2003 | 01:41 PM
T-sohctec's Avatar
Default Re: how much can stock rods handle?????? (LSiTurbo)
Wha?
have you ever taken a bottom end apart?
Old Mar 20, 2003 | 09:20 AM
LSiTurbo's Avatar
YES INDEED! ...otherwise i would not have not spoken up...
Old Mar 20, 2003 | 09:50 AM
Evil EG's Avatar
gothatch has 330hp on stock rods.
Old Mar 20, 2003 | 09:53 AM
@irborne's Avatar
stock rods can hold a good amount of power, but why don't you have new forged rods installed while you're at it, which is overall better for the long run.
[Modified by @irborne, 12:53 PM 3/20/2003]
Old Mar 20, 2003 | 11:47 AM
Cyber ITR's Avatar
Default Re: how much can stock rods handle?????? (@irborne)
jinxproof got 500whp with stock internals , with inline pro headgasket only
Old Mar 20, 2003 | 12:26 PM
Blaze45's Avatar
Brrraaaap!
Default Re: how much can stock rods handle?????? (SEX DR)
no way thats so crazy!!!! has he got any dyno sheets?
Blaze
Old Mar 20, 2003 | 12:34 PM
fast[R]'s Avatar
That's hard to belive
Old Mar 20, 2003 | 12:49 PM
DLB1994's Avatar
naw he got 350whp i think on stock internals and got 500+whp with pistons and rods on stock sleeves
Old Mar 20, 2003 | 12:57 PM
Cyber ITR's Avatar
Default Re: how much can stock rods handle?????? (DLB1994)
oh oops to myself
Slotz_HB
14
Jul 11, 2010 09:25 PM
Capt. Jimbo McSubipants
Nov 22, 2005 03:50 PM
gunmetalcivic
Mar 22, 2004 09:38 AM
Mr HYDE
59
Mar 18, 2004 09:35 AM
NOSED_CRX_VTEC
Sep 12, 2003 11:25 PM
