cheap place for Brembo Blankst and hawk pads?
Old Mar 19, 2003 | 09:35 AM
Audipwr1's Avatar
Default cheap place for Brembo Blankst and hawk pads?
Bought from them last spring, out in midwest somewhere? anyone got the link?
also what are people recomending for aftermarket drum brake components?
Old Mar 19, 2003 | 02:48 PM
keithv's Avatar
Default Re: cheap place for Brembo Blankst and hawk pads? (Audipwr1)
was it http://www.collettimotorsports.com?
Old Mar 19, 2003 | 03:59 PM
Audipwr1's Avatar
Default Re: cheap place for Brembo Blankst and hawk pads? (breaka_1_9)
exactly thanks
you have any suggestions for what to do with these pesky drum brakes?
Old Mar 19, 2003 | 04:01 PM
IMxWHITE's Avatar
exactly thanks
read what i posted about rear brakes in the https://honda-tech.com/zerothread?id=291852 post.. you dont need them
Old Mar 19, 2003 | 04:37 PM
keithv's Avatar
can you provide some more info about the pesky brakes?
Old Mar 19, 2003 | 04:51 PM
Audipwr1's Avatar
well i have zero knowledge how to work with them, thats why i was considering doing a disk swap, but the rumor is 20lbs per side more for disks?
so if i stay with drum brakes what shoes? and drums should i use?
(Track autocross application)
Old Mar 19, 2003 | 07:49 PM
the DR.'s Avatar
you'll be fine with oem shoes/drums, but you can get aftermarket shoes (but they are VERY pricey)
Old Mar 19, 2003 | 07:50 PM
Audipwr1's Avatar
Default Re: cheap place for Brembo Blankst and hawk pads? (SlicedBread)
i think more and more about disk swap damn drums
Old Mar 20, 2003 | 03:05 AM
keithv's Avatar
drums aren't too hard to work on once you've done them once. they have a few parts/springs that you need to play with, but its not that bad...
Old Mar 20, 2003 | 03:13 AM
USDM 4G VTEC's Avatar
actually drum brakes last a lil longer than discs
Old Mar 20, 2003 | 06:52 AM
Balled S2K's Avatar
Default Re: cheap place for Brembo Blankst and hawk pads? (USDM 4G VTEC)
To answer the original question about where to find Brembo blanks---the lowest I've found is actually NOPI @ $22.19ea
http://www.nopionline.com/index.cfm?...0Disc&vaffid=0
Old Mar 20, 2003 | 08:24 AM
Audipwr1's Avatar
Default Re: cheap place for Brembo Blankst and hawk pads? (Balled S2K)
perfect thanks
kaivorth
Honda Civic (2001 - 2005)
Jun 3, 2013 11:36 PM
mrdeadman
Sep 24, 2005 08:15 AM
RemerLex11
May 13, 2005 07:47 AM
6ghatch
32
Jul 17, 2004 04:33 PM
WuShu
May 18, 2001 12:43 PM
