ES Master Bushing Kit Installation on an Integra (DC2)
Old Mar 19, 2003 | 08:25 AM
jdmskin's Avatar
Default ES Master Bushing Kit Installation on an Integra (DC2)
yes....i have searched, and i havent found anything if anyone has a link.....let me know.....
thank you
Old Mar 19, 2003 | 09:09 AM
94CivicSi's Avatar
Default Re: ES Master Bushing Kit Installation on an Integra (jdmskin)
propane torch + hack saw + a lot of time. Burn the rubber out, cut the shell out, insert the ES busing.
When I first got mine, I took the LCA's to a shop to have the bushings pressed out. Waste of money, waste of time. My Dad has an old hot rod buddy who has a mechanical press at his garage so I'd thought I'd give that a try too. No chance. Not even close to enough pressure. Burn and cut is your best option.
Old Mar 19, 2003 | 09:10 AM
acura_typer's Avatar
Banned
Default Re: ES Master Bushing Kit Installation on an Integra (94CivicSi)
burning and stuff is also the best way to warp the LCA. I used a 20 ton press to get mine out.
Old Mar 19, 2003 | 12:55 PM
stevel's Avatar
Default Re: ES Master Bushing Kit Installation on an Integra (acura_typer)
i pressed all mine out. I think it was like a 9 ton press i used. There are thin metal sleeves on the outside of the rubber. On the upper front control arms I pressed out the bushing and outer sleeve all in one. You have to line everything up perfect because you have so much pressure on that thing if it jerks and something flies out it will be like a bullet. On the rest of them I didn't have the gonads to put that much pressure on them so i used a socket just slightly smaller than the sleeve and actually pressed out the rubber so all that was left was that thin outer sleeve. I then would put it in a vice, used a hacksaw to cut a slit in the sleeve and then use a punch and hammer to hammer the sleeve out. Worked well.
To me using the press was the way to go, i wouldn't want to burn all of those out. It takes a while so be patient.
Also, make sure you searched the archives. I know there's tons on this topic.
s
Old Mar 19, 2003 | 01:59 PM
MetalGunSI's Avatar
Default Re: ES Master Bushing Kit Installation on an Integra (stevel)
yes please help with some info.....while he's at work I'm the one thats going to be doing all the dirty work
It's all good tho....I get to drive the teggie...and remember Kyle I know how to turthe miles back
Old Mar 19, 2003 | 09:35 PM
3rdGteg's Avatar
Default Re: ES Master Bushing Kit Installation on an Integra (MetalGunSI)
How? I want to know!
Old Mar 20, 2003 | 06:11 AM
94CivicSi's Avatar
A propane torch is not going to heat a cast piece of steel enough to warp it. Even if you could get it that hot with a small torch, you're not leaving heat on the area long enough to heat it signifigantly. The rubber is barely changing state.
Hey, if you've got access to a hydraulic press, then by all means, that's the right way to do it. I don't. I was charged $200 by a shop to press out the 6 bushings in the LCA's. I can't afford that kind of labor.
Old Mar 20, 2003 | 10:05 AM
Armed Ferret's Avatar
http://www.overboost.com/story.asp?id=426
Old Mar 21, 2003 | 10:53 AM
jdmskin's Avatar
Default Re: ES Master Bushing Kit Installation on an Integra (SlowRedTeg)
SlowRedTeg
thanks!!!!!
Old Mar 21, 2003 | 11:09 AM
jdmskin's Avatar
its kind of hard to work in DC and then it takes you another two hours to drive home and then work on your car....you OFFERED to do this job so.....eat a phat one.
plus ill be home and to your house in time for us to finish the job toting a 30 pack under my arm....so quit your bitchin
jdmspoonitr
Aug 1, 2011 08:30 AM
FakeJDMEF8
Sep 9, 2006 07:52 PM
sircrxracer
12
Mar 17, 2004 09:05 AM
jdmb16acivic
Mar 13, 2004 08:37 AM
jdmskin
Mar 19, 2003 08:49 AM
