timing belt install
Old Mar 19, 2003 | 06:51 AM
RS_91's Avatar
Default timing belt install
ok i went to get new brakes for my car and after it was done we somehow ended up talking about my timing belt and the guys like yeah get that checked and replaced. i dont wanna pay like $200 for labor so i just wanted to know if anyone knows how to do it and can give me some info.
only post if you know what your talking about, if you have expeience with this or if you have done it before. thanks
Old Mar 19, 2003 | 07:05 AM
eg crunkmonster's Avatar
Default Re: timing belt install (Civic_EX)
Check out this website. When you change your timing belt, be sure to use an OEM Honda timing belt because the stuff at discount and autozone never fit properly. Also, change your water pump. While your at honda, remember to pick up honda bond for your water pump. Your gonna need a impact wrench also to loose the crank pulley and tighten it (its like 240 ft. lb of torque i thinkn). ALWAYS double check your timing also with the gear gears and the mark on the crank pulley. hope that helps
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
Old Mar 26, 2003 | 08:12 AM
Mocky57's Avatar
Default Re: timing belt install (eg cookiemonster)
yikes...
i was quoted $475 at the dealer today. the guy i had bought the car from didn't tell me that it hadn't been replaced. the car has 130k on it. *sigh*. there goes mod-money
Old Mar 26, 2003 | 08:14 AM
OC 335i's Avatar
Default Re: timing belt install (Mocky57)
yikes...
$475 is a ripoff.
Go find someone on the board local that'll do it. Or someone that can refer you to a reputable mechanic. Doesn't anyone do swaps in your area?
tracy209
Feb 17, 2014 10:03 PM
msgmkr
Sep 16, 2010 05:51 AM
cullylude05
Jan 17, 2006 06:22 PM
dmcivic
20
Oct 8, 2004 09:19 PM
NONKonformyst
Aug 13, 2002 11:23 AM
