No reverse w/ 99 si tranny
Old Mar 18, 2003 | 07:35 PM
Turbo(less)DB8's Avatar
Default No reverse w/ 99 si tranny
I got a 99 si tranny on my b18c1 and yesterday I tried to put in reverse to pull out of my driveway and it won't even let you put the shift in the rev gear. All the others work fine. I'm thinkin it might be the reverse fork but, 5th is on the same and works fine. Grrrrrrr
Old Mar 19, 2003 | 01:11 PM
Stripped Honda's Avatar
99-0104
Default Re: No reverse w/ 99 si tranny (nscivic)
did you drop the tranny ??? that is a common thing to happen if you drop the tranny ..... look on the bottom for damage
Old Mar 19, 2003 | 01:47 PM
Default Re: No reverse w/ 99 si tranny (Stripped Honda)
I don't think so. I jacked the car up and got under it. I didn't see and damage at all. Also the linkage looked ok.
Old Mar 31, 2003 | 10:45 AM
NeoGSR's Avatar
i got the same problem.....
1st and 2nd are kinda tricky too, sometimes they go in, other times i get stuck in 3rd....
bump
Old Mar 31, 2003 | 02:20 PM
dfoxengr's Avatar
Default Re: No reverse w/ 99 si tranny (NeoGSR)
honda trannys are notorious for not being able tog et into reverse easily..errr
Old Mar 31, 2003 | 03:18 PM
Bailhatch's Avatar
Default Re: No reverse w/ 99 si tranny (hybridvteceg)
I drive an 00 Si with 18k on it and the tranny sucks compared to a GSR or LS. It seems to be more notchy and rough than all the other Bseries engine trannys. going into 3rd is often rough. NOt going into reverse is common for hondas but that is usually just the gear teeth not quite lined up, no big deal.
Old Mar 31, 2003 | 06:01 PM
Kataku2K3's Avatar
Default Re: No reverse w/ 99 si tranny (Bailhatch)
If you got time pull the tranny and open it up... I'm willing to bet that you have a bent fork or interlock... Good Luck
Old Apr 6, 2003 | 01:37 PM
Default Re: No reverse w/ 99 si tranny (Kataku2K3)
I suspect the fork in this. Anyway, haven't had a chance open it up. About how much is a fork?
Old Apr 6, 2003 | 01:39 PM
bump
How's your 5th gear? Lemme what the outcome is.
P.S. thanx for the bump
Old Apr 6, 2003 | 01:42 PM
crxY-49's Avatar
i always put throw it in first or second before i put it in reverse and it goes in fine with no grinds everytime
Old Apr 6, 2003 | 01:44 PM
Default Re: No reverse w/ 99 si tranny (crxY-49)
Well, it used to work fine. Now, it won't even try to go in.
Old Apr 8, 2003 | 09:46 AM
PupaScoopa's Avatar
The rev gear selector arm work off of the 5th gear shift fork, so perhaps the finger on the shift fork that actuates the rev gear is bent?
Old Apr 8, 2003 | 05:07 PM
NeoGSR's Avatar
5th is fine, i think, it feels a little different going into gear, but other than that it performs fine....
RZFD
May 28, 2006 06:05 PM
lsvtec101
Apr 10, 2004 12:57 PM
USDM 4G VTEC
24
Apr 17, 2003 11:57 AM
