Exposed cam gears/timing belt. Bad in the long run?
Old Mar 18, 2003 | 07:31 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Exposed cam gears/timing belt. Bad in the long run?
When I installed my cams I did what alot of people do and cut my valve cover to expose the cam gears. I also have the top plastic piece of the timing belt cover off as well. Is this bad in the long run? What about water and other things getting on the belt?
Old Mar 18, 2003 | 07:34 PM
Eee Pee's Avatar
Default Re: Exposed cam gears/timing belt. Bad in the long run? (ActiveAero)
Knocks on wood!!!!!
I've had mine exposed for some time now.
But I hate to think what a flying rock could actually do.
Weary, but holding up.
Old Mar 18, 2003 | 07:40 PM
Turbo(less)DB8's Avatar
Yeah... bad. Just about lost my belt that way. I heard something hit the bottom of my hood and found a cut in my belt. Had the b*tch towed home.
[Modified by nscivic, 4:40 AM 3/19/2003]
Old Mar 18, 2003 | 07:43 PM
Padawan's Avatar
Darth ModerVader
https://honda-tech.com/zerothread?id=441690
Personally, I would buy a cheap/used/etc. cover to cut and use for tuning, then reinstall my stock cover after the tuning was complete. Like hoodpins on a CF hood - cheap insurance.
Old Mar 18, 2003 | 07:44 PM
Lord Helmet's Avatar
just hope it doesn't jump the tracks which will result in some serious damage to the engine.
and yeah the only thing I would be worried about is rocks from the road lodging themselves into the timing belt area. for water I wouldn't be too worried but that's me.
Old Mar 18, 2003 | 08:54 PM
J2turbo21's Avatar
Default Re: Exposed cam gears/timing belt. Bad in the long run? (sleeperciv)
I run without all the covers and havent had problems.I had one cover off before and something flew in and snap my belt.Hope this helps you out.
Old Mar 18, 2003 | 08:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: Exposed cam gears/timing belt. Bad in the long run? (J2turbo21)
I run without all the covers and havent had problems. I had one cover off before and something flew in and snap my belt. Hope this helps you out.
And you don't consider that a problem?
MadCoder
Mar 23, 2012 08:07 PM
masonracing
Mar 9, 2011 03:34 PM
civicmatt
19
Dec 11, 2002 11:13 PM
stupidfast
Oct 22, 2002 12:58 PM
1fastGSR
Nov 1, 2001 02:33 AM
