can someone identify stock usdm type headers
Old Mar 18, 2003 | 07:29 PM
roc's Avatar
roc
Default can someone identify stock usdm type headers
is there a number stamped on it.i need 2 know cause i am about to buy a set. i've seen the picture but it looks exactly like my stock b16 headers,but with different numbers stamped on them
Old Mar 18, 2003 | 09:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: can someone identify stock usdm type headers (roc)
If you have accurate pictures, the difference between the two manifolds should be obvious. Keep in mind that the upper halves of both headers are identical, it is only the lower halves that are different.
The stock B16A lower manifold should look similar to the 94-99 B18C1 in the diagram, although with a different flange at the collector and a longer length. The distinguishing characteristic is the two visibly seperate secondaries. As shown, the secondaries on the ITR manifold are more concealed. If you still aren't certain and you have pictures you can email, I don't mind looking at them, just PM me.
[Modified by Padawan, 1:26 AM 3/19/2003]
Old Mar 18, 2003 | 09:39 PM
AllMotorHB's Avatar
Default Re: can someone identify stock usdm type headers (Padawan)
What else is different between those A pipes besides looks?
Old Mar 18, 2003 | 10:17 PM
Padawan's Avatar
Darth ModerVader
Default Re: can someone identify stock usdm type headers (AllMotorHB)
The ITR collector is slightly (approximately 2 mm) larger when measured from the inside of the "anti-reversion" tubing. In addition, the ITR A-pipe is "taller" in order to clear the oil pan on the taller B18 block. Finally, it appears that the 2-1 merge may be slightly smoother/more gradual on the ITR piece, with different secondary lengths (while maintaining the same overall manifold length.
EDIT: I'll take a closer look tomorrow to better note the design differences.
[Modified by Padawan, 2:18 AM 3/19/2003]
Old Mar 18, 2003 | 11:52 PM
Patrick's Avatar
I have the USDM ITR exhaust mani and it does flow a good amount more then the stock GSR, but its not equal to and aftermarket header. It does have a more sleeper look to it though.
TeeB16
Mar 3, 2010 07:04 AM
eternity0114
Feb 18, 2004 04:42 PM
TypeRuz
Sep 25, 2003 11:18 AM
fowler!
Sep 6, 2001 07:34 AM
