Need information ASAP on battery issue.
Well, since last week my car will not start, all the accessory would work, and when i turn the key i would hear the starter clicking away and see the lights flashing with each click on the dash.
I thought it was the battery after reading:
https://honda-tech.com/zerothread?id=277018
So i ordered a new T1R battery, dropped it in, jump started since I was seeing the same scenario as before, but figured it might just be the battery isn't shipped fully charged. After driving it around for 40 minutes, stopped the car, shut it down, and it won't start backup.
Alternator and starter has only 11k miles on it.
Any one has suggestions? This sucks.
Re: Need information ASAP on battery issue. (bluesaint)
[Modified by TypeR00_0371, 5:01 AM 3/18/2003]
Re: Need information ASAP on battery issue. (TypeR00_0371)
So your saying even if i leave it on idle for 2 hours or even drive it for 2 hours, the thing will not charge? What good is a alternator?
Do you have AEM pullies on your car?? i had an alternator pully and that **** drain the **** out of my battery. Then i went back to the OEM pully and it solved the problem
your altenator may not be holding the charge. do this, start your car, and pull the neg. battery off, if your headlights get really dim or the ccar stops. you have a no charge in the alternator. check the fluid in the battery too, if its low, put distill water in it. other then that, i don't know what to tell you. do you have a sound system thats connected to it?
Re: Need information ASAP on battery issue. (SymphonyX)
this is with a brand new dry cell battery (fully charged) no amps or stereo of any kind, i can pull the negative off after car starts and nothing gets dimmed.
Check some auto parts stores in your area. If you have Advance Auto Parts, they'll check your charging system for free.
If you have a deep cycle battery, you will need to give it a deep cycle charge. Batteries are not magic. What you put in is what you get out. I would recommend charging the battery for at least 2 or 3 times longer than the deep cycle reserve in minutes.
For example, if the reserve is 200 minutes, charge it for 400 or 600 minutes. This is because the charging curve may not be linear, and if it is exponential, you will need extra charging time.
Do this and you should be good. If you have removed the negative terminal while the car was running and it still ran fine then you are OK on the alternator issue.
A battery's main function is to START your car.
Jon Black
Re: Need information ASAP on battery issue. (Jon Black)
Funny thing, I installed Tommy Gunn's earthing system this morning and the car can start with it installed.
I checked my stock two engine grounds and they are still connected and the cables still look good. So i guess there might be damage to the stock ground cables that i can't see with the naked eye.
yeah you might have to change your stock ground cables... get some nice thick ones to ground it properly. there's probably build up corrosion and all that nice stuff. it might solve your problem
Re: Need information ASAP on battery issue. (PupaScoopa)
[Modified by 94hondaLS, 12:56 AM 3/19/2003]
whophlungpoo
05-29-2006 07:39 PM
