How much race gas do you guy's usually take to a dyno session?????
Old Mar 18, 2003 | 04:52 PM
turbo Si's Avatar
Default How much race gas do you guy's usually take to a dyno session?????
Like it say's, I was thinking of getting 5 gallons for about a two hour or less session with no more than 20 pulls. I will be running VP C16?
Also, what is comparable to VP's C16 in other brands?
Old Mar 18, 2003 | 05:51 PM
turbo Si's Avatar
Default Re: How much race gas do you guy's usually take to a dyno session????? (turbo Si)
Anybody??
Old Mar 18, 2003 | 06:03 PM
boostaholic's Avatar
5 gallans should be plenty. Are you tuning just on c16 or tuning for pump, then draining the tank and adding c16?
Old Mar 18, 2003 | 06:25 PM
turbo Si's Avatar
Default Re: How much race gas do you guy's usually take to a dyno session????? (boostaholic)
Oh what's up Chris. Yeah it will be just on C16. Then Lawrence will turn down the boost and set the fuel parameters himself for pump gas. I should be able to go this Friday to take care of the block for you.
Old Mar 18, 2003 | 06:34 PM
Yeah i think 5 gallons will be plenty for the dyno. If you end up with some left in the tank, just have some fun on the street later Soon as i came home from the dyno i hit the street for some spirited driving
Old Mar 18, 2003 | 07:09 PM
turbo Si's Avatar
We'll wish me luck. I'm scheduled for this Saturday morning.
Old Mar 18, 2003 | 07:19 PM
Good luck man, tell Lawrence i said hey. Let me know how it goes! Shoot me a PM when you get that block.
Old Mar 18, 2003 | 07:33 PM
SiRkid's Avatar
when running some race gas, do you guys just leave your o2's in to get "eaten" up ?
Old Mar 18, 2003 | 08:04 PM
turbo Si's Avatar
Default Re: How much race gas do you guy's usually take to a dyno session????? (SiRkid)
Actually I am leaving my O2 in this time. It's only a 4 wire that came with the DFI kit. I have an extra O2 bung that's pluged up where we are going to put the wideband while tuning!
Old Mar 18, 2003 | 09:08 PM
Aeka GSR's Avatar
New User
i tune on pump gas since thats what i drive on.
Old Mar 18, 2003 | 11:57 PM
Kwuaymaikrup's Avatar
Can you have two separate tunes you can use for pump and race gas? I will be running Hondata and was wondering if I can switch between a pump gas tune and race tune. Thanks in advance,
-Ryan
Old Mar 19, 2003 | 03:38 AM
turbo Si's Avatar
Default Re: How much race gas do you guy's usually take to a dyno session????? (Kwuaymaikrup)
Yeah. You could have as many programs as your hard drive can fit!
Old Mar 19, 2003 | 07:00 AM
MaxBoost's Avatar
New User
5 Gallon's should be fine, but you might as well get like 7-8 so that you can have fun on the way to work tommorrow..lol..
My friend's hondata setup has a switch to change between maps. They are on the same hondata chip, all he does is flip a switch on the dash and he goes from a 93 octane map to a c16 map.
He made it himself and adapted it to his hondata stage2..not sure if it's possible w/ s200 but it should be cus they are almost the same thing.
BuiltnotboughT2
May 27, 2018 08:40 AM
liam821
Dec 21, 2008 11:57 AM
turbodano
Jul 8, 2008 06:26 PM
Andrie Hartanto
46
Sep 25, 2006 11:43 PM
B18C1CYA
May 29, 2005 02:28 PM
