DSM 450cc injectors for a GSR!
Old Mar 18, 2003 | 02:36 PM
tsi_turboawd's Avatar
Default DSM 450cc injectors for a GSR!
My friend has a '96 GSR thats gonna be turboed with my help. Can he use 450cc injectors w/ no problem along with T3/T4 turbo?
btw, i have dsm 450cc blue top jdm injectors up for grabs also! email me marq4g63@aol.com
Old Mar 18, 2003 | 03:13 PM
Diego Boost's Avatar
Default Re: DSM 450cc injectors for a GSR! (tsi_turboawd)
Yes, so long as he has some kind of fuel management. Stock Teg ECU's don't play well with larger injectors.
Old Mar 18, 2003 | 04:45 PM
Rob Dizzle's Avatar
Default Re: DSM 450cc injectors for a GSR! (Diego Boost)
hondata wont work with dsm injectors.
not sure about other tuning systems.
and, you will need to get it tuned, or get your ecu chipped with a program that is setup for the injector size you end up getting.
Old Mar 18, 2003 | 04:53 PM
avividmemory's Avatar
Default Re: DSM 450cc injectors for a GSR! (Bob-DC2)
and he'll need a resistor box because the dsms are peak/hold and ours are saturated
Old Mar 18, 2003 | 04:57 PM
threatcon13's Avatar
New User
Thats funny..hondata worked fine w/ my dsm 450cc injectors.
Old Mar 18, 2003 | 06:07 PM
Rory Breaker's Avatar
Default Re: DSM 450cc injectors for a GSR! (Threatcon13)
Hondata continues to work fine with my DSM 450's. Im still not sure why Doug posted that.
Youll need a resistor box from an older Honda, or you can use 10 watt 10 ohm resistors inline...$1.79 a pair if I remember right. That and a way to control them.
Old Mar 19, 2003 | 05:16 AM
Default Re: DSM 450cc injectors for a GSR! (newgsrdriver)
As for fuel management being needed. He has apexi SAFC, and fuel pressure regulator to go with it. So an aft. ECU or a Hondata isnt needed, or is it.
what exactly is a resistor box? isnt that just a little resistor in the ecu. Which older cars can we get one?
thx
Old Mar 19, 2003 | 06:14 AM
You can get the resistor box from an 88-91 Civic/CRX HF/Si, 92-96 Prelude, 90-91 Integra, etc.
DSM injectors are peak & hold as opposed to the stock saturated injectors. Honda computers require injector impedence of 10ohms, and peak and hold are much lower. The resistor box compensates for the difference.
Old Mar 27, 2003 | 12:14 PM
Lost Type R's Avatar
450cc can tune well with AFC hack?
Old Mar 27, 2003 | 12:19 PM
Ramocheese's Avatar
Default Re: DSM 450cc injectors for a GSR! (Lost Type R)
If you don't run the resistor box, you can fry a portion of your ECU because the ohm ratings are off. You need the resistor box to allow the ECU to properly use the injectors.
You also need some kind of fuel management that will allow you to lean/richen areas up in your map.
ceemarun
Aug 7, 2015 05:21 PM
Keangdawizes
Oct 31, 2008 11:56 PM
Adriano
Oct 15, 2002 06:53 PM
