Anyone use Total Seal Rings?
Old Mar 18, 2003 | 12:54 PM
TeStUdO's Avatar
Default Anyone use Total Seal Rings?
have any of you guys used total seal rings? im in a rebuild right now i was thinking about these because im boosting, but would JE rings be just as good?
Old Mar 18, 2003 | 02:27 PM
MiraiZ's Avatar
Default Re: Anyone use Total Seal Rings? (00si5)
you mean total **** rings? I have not heard a single good thing about them...use OEM or the rings that came with your pistons.
Old Mar 18, 2003 | 03:28 PM
Diego Boost's Avatar
Default Re: Anyone use Total Seal Rings? (MiraiZ)
I too have hear that total seal sucks, but that's just what I've heard..
Old Mar 18, 2003 | 03:37 PM
shermanyang's Avatar
Default Re: Anyone use Total Seal Rings? (Diego Boost)
I used it on my last setup and it sucked ***!! luckly for me this time, the ross pistons came with some rings.
Old Mar 18, 2003 | 03:43 PM
93LSivic's Avatar
Default Re: Anyone use Total Seal Rings? (shermanyang)
JE rings = Hastings
Old Mar 18, 2003 | 03:45 PM
falcongsr's Avatar
What is this crap?
total steal?
Old Mar 18, 2003 | 04:45 PM
Aeka GSR's Avatar
New User
Default Re: Anyone use Total Seal Rings? (falconGSR)
what exactly makes total seal total ****? I've never used them but I would like to know. Is it that a boosted engine needs a little bit of blowby or what?
Old Mar 18, 2003 | 05:04 PM
MiraiZ's Avatar
Default Re: Anyone use Total Seal Rings? (Aeka GSR)
Quite the opposite....
They take a long time to seat (if they do at all) for one thing. Second, I heard that when you hone the crosshatch on your cylinders, that they need to be really coarse for it to seat.
[Modified by MiraiZ, 11:05 AM 3/19/2003]
Old Mar 18, 2003 | 05:28 PM
S2KP's Avatar
I've heard total seal rings are bad for Hondas
Old Mar 18, 2003 | 06:04 PM
Default Re: Anyone use Total Seal Rings? (Turbo_Siii)
here's my compression just for your info: cylinder 1= 150, 2 = 85, 3 = 50, 4 = 140. I ran them for about close to 6 months!! damn things didn't want to settle in. so that's why i'm changing pistons and rings.
Old Mar 18, 2003 | 06:07 PM
red cx's Avatar
I put total seal rings in my motor and i dont like them im going to switch to oem
Old Mar 18, 2003 | 07:31 PM
BoostedSi's Avatar
Default Re: Anyone use Total Seal Rings? (b16aturbopwrd)
i have total seals in my motor right now, compression was 170, 175, 170, 170. The only reason i got them was because i needed them asap to finish my rebuild and drive my car. Car has had about 25k miles on it since the last rebuild...no problems since.
Old Mar 18, 2003 | 07:43 PM
blmracing's Avatar
Default Re: Anyone use Total Seal Rings? (BoostedSi)
I used total seal in my b16a w/no problems. I got them in my new motor too. It all depends on the machine shop that does the honing.
Old Mar 18, 2003 | 08:06 PM
BoostedSi's Avatar
Default Re: Anyone use Total Seal Rings? (onesikvtec)
I even honed the block myself and no problems
Old Mar 19, 2003 | 11:26 AM
TeStUdO's Avatar
well im definitely not getting them then. thanks alot guys
Mugencrxsir1
Oct 23, 2006 04:32 PM
Mr. Vapor
Jan 15, 2003 04:54 PM
fastludeh22
Sep 8, 2002 01:18 PM
samiam
Jan 28, 2002 04:43 AM
