Problems with B16a swap. Please help
Old Mar 18, 2003 | 12:14 PM
madman13lm's Avatar
Default Problems with B16a swap. Please help
Ok. First off, I bought the car with the swap already complete, Im just trying to fix it before I start modding it further. The car doesnt like to Idle until its been running for a little while. I know that the battery is going bad and Im not sure if the alternator is following suit. There is no exhaust on the car other than a header, so there is no O2 sensor at the cat, since there isnt one there to hook up yet. Also, the ECU seems to randomly change the rev limit. The first time that it did it was when I had lost a lot of coolant. This we later found out was because of a faulty radiator cap. It set the rev limit to 3k. Now that is fixed, but it randomly sets the rev limiter to 7k rather than 8.2k. My header has 2 O2 sensors but only one is plugged in. Do I need another wiring harness in order to plug it in? Should I not plug it in? Im just curious. Also, how do I know for sure if the vtec function is working properly? From what I have heard it takes some wiring in order to get that to work properly. Any ideas as to what could be going wrong with my car, please let me know.
Adam: Just happy to finally have a swaped Rex.
Old Mar 18, 2003 | 12:38 PM
riceboy's Avatar
Default Re: Problems with B16a swap. Please help (madman13lm)
what ECU are you using.
Old Mar 18, 2003 | 01:00 PM
madman13lm's Avatar
Default Re: Problems with B16a swap. Please help (riceboy)
the ECU came with the complete swap when he put it in
Old Mar 19, 2003 | 11:12 AM
riceboy's Avatar
look on the ECU, take the center three numerals/letters of the part #
Old Mar 19, 2003 | 12:39 PM
madman13lm's Avatar
its a B20-PR3-00. Sounds like a Pr3 to me then. I hope this helps.
Old Mar 19, 2003 | 12:57 PM
SEA Hag's Avatar
Pr3s have a cold rev limit so you cant engage vtec or rev to 8k if your motor is not warmed up.
Old Mar 19, 2003 | 03:02 PM
pokemon's Avatar
Default Re: Problems with B16a swap. Please help (SEA Hag)
Or if the vtec wiring isn't hooked up also.
Old Mar 19, 2003 | 10:23 PM
madman13lm's Avatar
Default Re: Problems with B16a swap. Please help (pokemon)
We have a winner here folks. I went to the track today. I got a marvelous 16.443@86.2 We decided to check out the wiring and found out that there are several problems. There are wires hooked where they shouldn't be, there are missing wires. Too top it all off, the O2 sensor that isnt hooked up is the secondary sensor that is required for Vtec. So Im off to rewire my car and pray I get it done in time to run at the track on friday.
macknjack
10
Feb 11, 2010 08:35 PM
Libertariat
Aug 20, 2008 10:54 AM
krazie1
Aug 12, 2005 09:46 PM
BlVlW313
10
Dec 19, 2002 07:35 AM
slowpokesi
25
May 27, 2002 07:01 AM
